Miranda IM 0.6.2: Korrektur wegen AOL Instant Messenger
Mit der Version 0.6.2 bereinigt der Multiprotokoll-Instant-Messenger
Miranda IM eine Unvertraeglichkeit mit dem AOL Instant Messenger. Ein
Fehler fuehrte dazu, dass damit keine Nachrichten mehr ueber das AOL-
Netzwerk empfangen werden konnten. Die aktuelle Version von Miranda IM
bringt ausserdem weitere Fehlerkorrekturen.
Es gibt übrigens mittlerweile schon v0.6.3! Hier die 3 Changelogs:
v0.6.1:
ZitatAlles anzeigenChanges:
Enhancements
- Added option to enable/disable UPnP support
- Improved control/shift/enter behavior in chat windows
Bugfixes:
- History button in chats didn't open history
- Fixed network bind plugin compatibility issues with older plugins
v0.6.2:
Enhancements
- Improved unicode support in path utilities
- UPnP routers that use chunked encoding are now supported
- Added ability to enable/disable sounds globallyBugfixes
- Tooltips on button controls displayed incorrectly in ANSI version
- Enabling/disabling first group of sounds in options didn't enable apply button
- Path in sound options was cut off for long paths
- Some dialog backgrounds were not using system colors
- Global hotkeys didn't work correctly
- AIM: Messages were not received properly
- AIM: Fixed formatting of outgoing unicode messages (AIM 5.9 was affected)
- ICQ: Fixed compatibility issues with ICQ 6
- ICQ: Fixed Meebo client detection
v0.6.3:
ZitatChanges:
- Pin to Desktop was broken
- AIM: Auto response messages weren't shown as auto responses
