Zum Glück kann man's ja immernoch selbst zusammen bauen
MediaInfo CLI v0.7.30, Intel C Compiler 11.1.060 Update-5, statisch gelinkt:
http://www.mediafire.com/file/mfq5m2oze….2010-03-27.zip
0.7.31
Zitat+ scte 20 closed caption support
+ difference between width/height in the container and in the raw stream
+ avc: Gop structure
+ mxf: More raw stream formats are detected (mpeg-4 visual, a-law...)
+ dv: Better detection of dvcpro 50 and 100
x dv: Less files without the right extension wrongly detected as dv
MediaInfo CLI v0.7.31, Intel C Compiler 11.1.060 Update-5, statisch gelinkt:
http://www.mediafire.com/file/nu2kwywmm….2010-04-17.zip
0.7.32
ZitatAlles anzeigen+ Danish, French translations updated
+ MPEG-7 output improvements
+ DV: Better detection of DVCPRO 50 and 100 (again), especially in MXF
+ P2: support of P2 XML files and P2 directory structure
+ XDCAM: support of XDCAM XML files and XDCAM directory structure
+ N19: More attributes
+ ISO-639-2 3-letter standard for language field (for third-party software)
+ Additional commercial name of a stream or container (XDCAM IMX, DVCPRO, AVC-Intra 50...)
+ MXF: support of detection of files without Track number in the headers
+ MXF: Operational Pattern
+ MPEG-4: Aperture size support
x AVC: some files were wrongly analyzed (frame rate...)
x AVI: better support of files with only one big data chunk (professional cameras)
x MPEG-4: Huge memory usage with some files (files with DV and PCM)
x DVR-MS: width/height was wrong in previous version
MediaInfo CLI v0.7.32, Intel C Compiler 11.1.065 Update-6, statisch gelinkt:
http://www.mediafire.com/file/w1hwmjgy2….2010-05-03.zip
0.7.33
Zitat+ Slovak language added
+ Colorimetry field is replaced by Color space and Chroma subsampling
x Some word were not translatable
x Solaris port was broken
MediaInfo CLI v0.7.33, Intel C Compiler 11.1.065 Update-6, statisch gelinkt:
http://www.mediafire.com/file/mvg2ydn1i….2010-05-15.zip
0.7.34
ZitatAlles anzeigen+ New icons set, thanks to Kevin Redon, based on Gnome themes: Neu, Experience, Gnome 2.18
+ WebM support, sponsored by http://digi-metrics.com/
+ LXF (Harris/Leitch) support
+ #3008704, IVF (Indeo Video Format) support
+ #3002376, Blu-ray: Source (.m2ts) for the .mpls parser
+ DV: handling of unsynched streams
+ Basic view, Bit Depth is added to the audio part
+ FLV: Framerate info for some not yet supported weird files
+ Demux (library only): demuxed packets can be forced to contain 1 complete frame
+ XML output: MediaInfo version
+ Parsing speed (Library only): option for a quicker analyzing, but with some missing features
+ AVI and Huffman (HFYU): Colorspace
+ AVI and Fraps: Colorspace
+ AVI and Lagarith: Colorspace
+ MPEG-4: Channel map basic support
x CEA-708: Skipping some malformed streams
x JPEG/M-JPEG: Resolution was in some random other field
x #3001707, AAC in MP4: mono aac file detected as stereo
x AVI: crash with some malformed files
x AVI: Stream identifier was not filled in some cases
x MPEG-PS: some files were not well detected
x WAV: Bit Depth is back
x WAV/PCM: Byte sign was wrong if Bit depth >8
x Decimal point issues with some specific compilers/OS
x MPEG-4: removing support of btrt atom for average bitrate, too many wrong values
x AVI: crash with some specific files (avc1 CodecID)
x MPEG-4+AAC: Trying to better detect the (non)presence of PS if there is no PS header
x MPEG-TS/PS: more precision on duration
MediaInfo v0.7.34:
http://code.google.com/p/mulder/downl…11.zip&can=2&q=
(Kommandozeilen-Version, Intel C Compiler 11.1.065 Update-6, statisch gelinkt)
MediaInfo v0.7.35:
http://code.google.com/p/mulder/downl…06.zip&can=2&q=
Changelog MediaInfo Lib:
ZitatAlles anzeigenVersion 0.7.35, 2010-09-05
+ Teletext subtitle support
+ DVB subtitle support
+ CEA-608/708: language
+ Library: "Per frame" interface, like ffmpeg
+ AFD: AFD (Active Format Description) value and detail
+ MPEG-TS: SCTE35 detection and parsing
+ MXF: Ancillary data (S436M) support
+ MPEG-TS: Codec ID (stream_type)
+ MXF parser improvements
x #3036119, MKV: default language value is eng
x DV: weird display with some DV with synch problems.
x AVC: wrong detection of bitrate mode for AVC in MP4
x MPEG-TS: crash and wrong detection of some non MPEG-TS files
Changelog MediaInfo CLI:
+ Arabic language added
0.7.36
ZitatAlles anzeigen+ Binaries (libraries, programs and installers) are digitally signed
+ HDV 720p/1080i/1080p commercial names support, sponsored by http://www.chyro.fr/
+ Raw TrueHD support
+ MP4: "lpcm" (PCM from DVD) Support (with channel positions)
+ MKV: compression mode (zlib...) display
+ WAV: support of AAC (ADTS) with CodecID 0x8180
+ WMV: Handling of weird Aspect Ratio information in Extended Content Description
+ #3082158, .m4b file extension support
+ #3087674, Ut Video Lossless support
+ #3087677, WebP: basic support (detection only)
+ #3072929, MP4: DTS Express support
+ MPEG-4: Handling of external files referenced by "code" atom
+ M-JPEG and M-JPEG 2000 are renamed JPEG and JPEG 2000
+ MP4 and HDV 1080i: detecting containers lying about width (saying 1920 but it is 1440)
+ DTVCC Transport and SCTE20: Option for displaying empty streams
+ DPX format detection
x Windows x64 explorer tooltip is back!
x #3034092, MPEG-TS: hang up if program is modified (zapping) in the file
x AAC: removal of empirical detection of SBR and PS (too many problems)
x AVI: trusting in priority frame count from index of indexes with broken files
x MKV: AVC "unknown profile" removal
x AVC: some frame rates were reported as twice the real frame rate
x #3029308, Id3v2: support of frames with Unsynchronisation bit set
x #3065114, MPEG-Video: duration calculation issues with raw streams and open GOPs
x AFD: crash with malformed streams
x MPEG-7 output: missing references for MPEG-4 Visual and RF64
x #3086701, ID3: freeze/crash with ID3 tag at the end of the the file
x LXF: some files were not completely analyzed (missing video)
x JPEG: Chroma subsampling value was always set to 4:2:0, wrong
x MP4 with MPEG Video: do not trust anymore raw stream timecode
MediaInfo v0.7.36
http://code.google.com/p/mulder/downl…25.zip&can=2&q=
Kommandozeilen-Version, statisch gelinkt, x86 (ICL11) + x64 (MSVC9) Builds.
0.7.37
ZitatAlles anzeigen+ DPX format support
+ Compression mode (Lossy / Lossless) information (note: JPEG 2000 "profile" is moved to this new field)
+ #3095129, AVI: MLC Lossless codec support
+ #3095136, AVI: AMV Video Codec support
+ IFO: chapter information (thanks to Bastian Wegener)
+ MPEG-4: header size / data size / footer size information (in advanced mode)
+ MPEG-4: AVmp CodecID (.mov referencing .mxf) support
x MXF: avoiding infinite loop due to circular reference
Hier ist ein aktuelles MediaInfo v0.7.37 Build:
http://www.mediafire.com/file/114xod0n4….2010-11-24.zip
Dieses Build wurde statisch gelinkt und für die korrekte Unicode-Ausgabe (UTF-8) modifiziert, so wie hier diskutiert.
0.7.38
ZitatAlles anzeigen+ Danish, Ukrainian, French, English, Russian translations updated
+ uClibc compatibility, thanks to Metin KAYA
+ MPEG-TS: ID in all streams if a TS streams contains several substreams
+ JPEG in MOV: Scan type
+ AAC: implicit SBR and implicit PS detection (complete HE-AAC and HE-AACv2 detection)
+ AAC/LATM: more details (channels, profile...)
+ AAC/SL: more details (channels, profile...)
+ MPEG-TS and MPEG-PS with trace feature activated (Linux/Mac by default): speed improvement
+ DTS: indication of HD and Core configurations if there is an HD part
+ #3118446, MXF: VC-3 (DNxHD) detection
+ VC-3 (DNxHD) raw stream support
+ VC-3 (DNxHD): Bit depth
+ MPEG-TS: option for ignoring ATSC transport_stream_id indication
x MPEG-TS: some teletext and DVB subtitles were not detected
x #3111584, MXF: phantom track with weird result if an unknown track is found
x #3116952, DTS and AC-3: was set as lossy in all cases (DTS Master Audio and AC-3 TrueHD are lossless)
x #3137160, ADTS: some files with wrong extension were not correctly detected
MediaInfo v0.7.38
http://www.mediafire.com/file/5z3j23gf6….2010-12-18.zip
(CLI, statisch gelinkt, x86 und x64 Builds, ICL11/MSVC9, das UTF-8 Patch wurde committet)
0.7.39
ZitatAlles anzeigen+ Turkish, Russian translations updated
+ OGG: more CELT attributes, thanks to Lionel Duchateau
+ DV: better detection of display aspect ratio for specific (non standard?) streams
+ MPEG-7: support of ISO-IEC 13818-2 / H.262 (MPEG Video) version 2000 (multi-view / 4:2:2)
+ MXF: Clean aperture size support
+ D-10 (AES3) in MXF: real channel count
+ MPEG-TS: detection and analysis of ADTS in stream_id_extension
+ #2943900, MPEG-4 Visual: count of maximum consecutive B-frames
+ MP4: Handling of Nero library information atom
+ Id3: TAG+ support
x #3140453, MKV with AAC: support of HE-AAC v1/v2 detection even if AudioSpecificConfig is missing
x #3138883, ID3v2: crash in some cases if Data length indicator is used
x #3139417, MPEG-PS: duration for caption detection was shorter than expected
x #3139276, H.263: more precision about the different flavors of H.263
x AVI and MPEG-2 Audio Layer 3: error if audio stream duration estimation
x FLV: better handling of weird bitrate metadata
x D-10 (AES3) in MXF: Bit rate was wrong
x AC-3: crash if false-positive detection of AC-3 and CRC is valid and bsid is wrongly set
x #3141059, FLV: trying to detect partial files (so metadata are wrong) and using timestamps instead
x #3141052, AVI: wrong duration, no detection of rec chunks, with some files
x #3145968, RealMedia: not integer frame rate handling + HE-AAC filling
x Id3v2: bad handling of some tags
x MPEG-TS/PS: Frame count / duration accuracy of some very specific files
x MPEG-TS/PS: Not counting non-decodable frames (without the corresponding I-Frame)
MediaInfo v0.7.39
http://code.google.com/p/mulder/downl…04.zip&can=2&q=
(CLI, statisch gelinkt, x86 und x64 Builds, ICL11/MSVC9)
0.7.40
ZitatAlles anzeigen+ QuickTime: detection of AES3 and Dolby E
+ QuickTime: Apple CEA-608 and CEA-708 (in CDP) support
+ JPEG 2000: Chroma subsampling
+ JPEG 2000 in MXF: Color space
+ JPEG 2000 in MPEG-4 and MJ2: Color space
+ MPEG-4: mx5p CodecID support
+ ISO 9660 (CD/DVD/Blu-ray dump) detection
x MPEG-TS: wrong detection (as encrypted) of some streams with a lot of transmission errors
x MPEG-TS: wrong management of some PAT/PMT updates (real time parsing)
x MPEG Video: wrong duration with some raw streams
x FLV: wrong duration with some files
x libcurl: crash if requesting a libcurl URL but libcurl library not present
x MPEG Audio: crash with some malformed files
x MPEG-4: error between recorded date and encoded date
0.7.41
Zitat+ MPEG-TS: random cases with full parsing of the file
