DVDStyler is a cross-platform DVD authoring System.
It is Free software distributed under the GNU General Public License (GPL).
23 January 2006: DVDStyler v1.5 beta 4 Released!
You can download the latest versions of DVDStyler here.
Changes:
added support for SVG-gradients
fixed copy&paste
some other small changes
Note: linux users should install the latest wxSVG library (v1.0b5).
Features
The main DVDStyler features are:
you can drag and drop MPEG files directly
you can import image file for background
you can create NTSC/PAL menus
you can place text and images anywhere on the menu screen
you can change font/color
you can put basic text buttons, change font/color and background color
you can copy and paste any menu object
you can set chapters for each movie
you can change post command for each movie
For more information see Docs.
