hi,
folgendes, ich hab ein MKV (h264) mit 2 Tonspuren.
Hier mal die daten dazu:
+ EBML head|+ Doc type: matroska|+ Doc type version: 1|+ Doc type read version: 1+ Segment, size 1443118976|+ Seek head (subentries will be skipped)|+ EbmlVoid (size: 4012)|+ Segment information| + Timecode scale: 1000000| + Muxing application: libebml v0.7.6 + libmatroska v0.8.0| + Writing application: mkvmerge v1.6.5 ('Watcher Of The Skies') built on Dec 7 2005 18:53:53| + Duration: 5915.882s (01:38:35.882000000)| + Date: Sun Feb 05 14:20:35 2006 UTC| + Segment UID: 0xb1 0x82 0x7c 0x75 0xab 0xde 0x59 0xa8 0x81 0x15 0xe0 0x5f 0x6e 0x12 0x80 0x41|+ Segment tracks| + A track| + Track number: 1| + Track UID: 594113940| + Track type: video| + Enabled: 1| + Default flag: 1| + Forced flag: 0| + Lacing flag: 0| + MinCache: 1| + Timecode scale: 1.000000| + Max BlockAddition ID: 0| + Codec ID: V_MPEG4/ISO/AVC| + Codec decode all: 1| + CodecPrivate, length 35| + Default duration: 41.708ms (23.976 fps for a video track)| + Video track| + Pixel width: 720| + Pixel height: 472| + Interlaced: 0| + Display width: 839| + Display height: 472| + A track| + Track number: 2| + Track UID: 3853573274| + Track type: audio| + Enabled: 1| + Default flag: 1| + Forced flag: 0| + Lacing flag: 1| + MinCache: 0| + Timecode scale: 1.000000| + Max BlockAddition ID: 0| + Codec ID: A_AAC/MPEG4/LC| + Codec decode all: 1| + CodecPrivate, length 2| + Default duration: 21.333ms (46.875 fps for a video track)| + Audio track| + Sampling frequency: 48000.000000| + Channels: 2| + A track| + Track number: 3| + Track UID: 1720908431| + Track type: audio| + Enabled: 1| + Default flag: 0| + Forced flag: 0| + Lacing flag: 1| + MinCache: 0| + Timecode scale: 1.000000| + Max BlockAddition ID: 0| + Codec ID: A_AAC/MPEG4/LC| + Codec decode all: 1| + CodecPrivate, length 2| + Default duration: 21.333ms (46.875 fps for a video track)| + Audio track| + Sampling frequency: 48000.000000| + Channels: 2
Das ganze Demuxe ich mit MKVextractGUI. Mit YAMB speichere ich das Video und die 2 Tonspuren in einem MP4-Container (bei dem H264 gebe ich an 23.976 fps, was eigentlich auch stimmen sollte). Das ganze dann mit MKVMergeGUI in ein MKV speichern. Das dumme ist jetzt das das Video nicht mehr synchron mit dem Audio läuft.
Hier mal die Daten zu dem neuen MKV:
+ EBML head
+ Segment, size 1440930478
|+ EbmlVoid (size: 4027)
| + Writing application: mkvmerge v1.6.5 ('Watcher Of The Skies') built on Mar 17 2006 17:24:57
| + Duration: 5988.066s (01:39:48.066000000)
| + Date: Mon May 29 18:46:30 2006 UTC
| + Segment UID: 0x8f 0xbc 0xee 0x81 0x8d 0x51 0x84 0x5e 0x8a 0x14 0x53 0xe0 0xaa 0xe3 0x7f 0xc0
|+ Segment tracks
| + A track
| + Track number: 1
| + Track UID: 2889211308
| + Track type: video
| + Enabled: 1
| + Default flag: 1
| + Forced flag: 0
| + Lacing flag: 0
| + MinCache: 1
| + Video track
| + Pixel width: 720
| + Pixel height: 472
| + Interlaced: 0
| + A track
| + Track number: 2
| + Track UID: 666760124
| + Track type: audio
| + Enabled: 1
| + Default flag: 1
| + Forced flag: 0
| + Lacing flag: 1
| + MinCache: 0
| + Audio track
| + Channels: 2
| + A track
| + Track number: 3
| + Track UID: 1705057213
| + Track type: audio
| + Enabled: 1
| + Default flag: 0
| + Forced flag: 0
| + Lacing flag: 1
| + MinCache: 0
| + Audio track
| + Channels: 2
|+ EbmlVoid (size: 1024)
|+ Cluster
Alles anzeigen
Kann mir jemand sagen woran das evtl liegen könnte?
Das komische ist, das es bei einem anderen Video mit dem gleichen Format funktioniert, nur das hier will nicht...:mad:
Der Grund warum ich das mache ist, weil ich noch eine weitere Tonspur hinzufügen will.
mfg
