AutoMKV - Alternative für AutoGK
  • AutoMKV 0.96 beta 14
  • AutoMKV 0.96 beta 19
    Here the beta 19 uptade, not a big one, not a bug fix release (sorry pal) , just a mix of fixing and new fuction
    Edit:
    ADDED: Support to DivX H.264 encoder
    ADDED: Average_Lem_Gauss_Denoise.lvl to scrip for hgavs or qmtrim. It's a pretty direct resize filtering based on gauss resize and LEM
    FIXED: Delete Job now delete the queue.bat line
    FIXED: Safe Deinterlacer triggered always a deinterlacer
    CHANGED: Display encoding stats now will show the x264.exe encoding window AND will be faster then not showing it
    FIXED: x264.exe will start at idle priority and will minimized
    UPDATE: DGIndex 1.5.2, HCEnc 0.23, MKVToolnix 2.2.0, x264 0.61.957M 7ce0f2c, medianfo 0.7.7.4, tsmuxer 1.8.4b, eac3to2.60, bass audio 2.3, DGAVCDec 1.00b35, SoundOut test 2, NicAudio 2.01, FFmpegSource 1.21, FFmpeg Sherpya-r14277
    Download
    Einmal editiert, zuletzt von Schotenhüter (3. September 2008 um 21:45)
  • AutoMKV 0.97 beta 1 (with Psy + B-Adapt + DivX H.264)
    Download
  • AutoMKV 0.97 beta 4 (with Psy + B-Adapt + DivX H.264)
    FIXED: MOD16 Crop not remembered on queue (thanks to Hedzin)
    FIXED: Is no more possibile to check both "Use DSS x A/V" and "Use DSS x Audio" (thanks to ryc0203)
    FIXED: Use of external subtitle with avi container AND burnt subtitle (thanks to YIG)
    FIXED: Audio was double encoded when checking "USE DSS x A/V" (thanks to ryc0203)
    Download
  • new full package 0.97
    ADDED: In advanced settings possibility to show only forced subtitle (beta)
    FIXED: Deinterlacer routines will run simultaneusly. Faster detect
    FIXED: Low cpu usage on x264 encoding
    CHANGED: Recked all x264 profiles
    UPDATE: x264 0.65.999M cc51047,MKVmerge 2.3.0, added Anime Profile, added 2 pass fast profile , eac 2.65,dgAVCDec 1.0.2
  • Update 0.97.1
    ADDED: "Specify AR Input" usefull when input isn't mpeg2. Use it for mkv/avi/ogm..
    ADDED: "Only Forced Sub"
    FIXED: "Allow Hybrid Order/Pattern" wasn't saved on "Load/Save Settings" (thanks to AGKnotUser)
    FIXED: "--sar" is working for xvid/x264/divx
    CHANGED: Force MOD16 now applies to crop and resize
    CHANGED: Height is now MOD8 (less AR error)
  • AutoMKV 0.98
  • 0.98.2
    FIXED: In some mkv file audio could not be extracted (thanks to chengbin)
    FIXED: now when ffmpegsource is enbled and directshowsource for audio is enabled too, audio isnt' extracted
    FIXED: other minor glitch
    CHANGED: Apple Profile, PSP profile, Archos profile
    UPDATE: eac3to 3.03,x264 rev 1083, MediaInfo, mp4box, oggenc, aften, dgavcdec,ffmpeg
    Download
  • 0.98.3
