Kann mir jmd weiterhelfen, hab mir megui installiert und versucht nen capture in xvid q=4 + mp3 vbr 50 zu encoden. Leider kommt da nur mist raus siehe bild
Bild: http://img1.myimg.de/1823.jpg
Logfile:
Generating jobs. No desired size.
User doesn't care what the filesize is. Leaving bitrate/qp/crf at the profile's valueStarting job job1-1 at 15:47:49
encoder commandline:
successfully started encoding
Processing ended at 15:47:57
Log for job job1-1
Channels=2, BitsPerSample=16, SampleRate=44100Hz
C:\Programme\megui\tools\lame\lame.exe -V 4 -h --silent - "C:\Dokumente und Einstellungen\Standard\Desktop\1.mp3"
Job completed successfully and deletion of intermediate files is activated
job job1-1 has been processed. This job is linked to the next job: job1-2
No desired size. Continuing without making any changes.
Starting job job1-2 at 15:47:57
-i "C:\Dokumente und Einstellungen\Standard\Desktop\1.avs" -single -cq 4 -smoother 0 -max_key_interval 250 -nopacked -closed_gop -lumimasking -threads 1 -avi "C:\Dokumente und Einstellungen\Standard\Desktop\1.avi"
Processing ended at 15:50:19
Log for job job1-2
xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003
Trying to retrieve width and height from input header
Input colorspace is YV12
xvidcore build version: xvid-1.2.0-dev
Bitstream version: 1.2.-127
Detected CPU flags: ASM MMX MMXEXT SSE 3DNOW 3DNOWEXT TSC
Detected 1 cpus, using 1 threads.
Tot: enctime(ms) =94585.00, length(bytes) = 14264487
Avg: enctime(ms) = 63.23, fps = 15.82, length(bytes) = 9535
I frames: 8 frames, size = 45061/ 360495, quants = 4 / 4.00 / 4
P frames: 511 frames, size = 19772/10103530, quants = 4 / 4.00 / 4
B frames: 975 frames, size = 3897/3800462, quants = 7 / 7.00 / 7
This is a CQ job so there's no desired bitrate. Obtained video bitrate: 1914756 kbit/s
job job1-2 has been processed. This job is linked to the next job: job1-3
Starting job job1-3 at 15:50:19
-v "C:\Dokumente und Einstellungen\Standard\Desktop\1.avi" -a "C:\Dokumente und Einstellungen\Standard\Desktop\1.mp3" -o "C:\Dokumente und Einstellungen\Standard\Desktop\1-muxed.avi"
Processing ended at 15:50:20
Log for job job1-3
DivXMux: Version 6.1 Build Num: 36
Output File Streams:
TrackId 0: Video Stream: From AVI
Frame Rate: 25000.000000
Resolution: 640x528
TrackId 1: Audio Stream: From MP3
SamplesPerSec: 44100
BlockAlign: 1152
ERROR: DIVXMUX_DISKSPACE while muxing
Alles anzeigen
