16.4
* The Windows installer now includes mpv as well.
* Now it's easier to switch between mplayer and mpv (Preferences -> General,
select either mplayer or mpv as multimedia engine).
* The extrastereo filter works again when using mpv.
* Possibility to use the VLC shortcuts. (Preferences -> Keyboard and
mouse, click the load button, select vlc.keys)
* Possibility to enable mouse gestures (when the mouse is dragged up or down
in the video window the volume changes. If dragged left or right it
changes the time position).
You can enable this option in Preferences -> Keyboard and
mouse -> Mouse -> Drag function: seek and volume.
* A fix for saving bookmarks.
* The option for streaming sites in Preferences -> Network is
different now, and allows these values:
Disabled: support for video sites is turned off
Auto: enables the internal support for YouTube and uses mpv + youtube-dl
for the rest of sites
YouTube: only the internal support for YouTube will be used
mpv + youtube-dl: uses mpv + youtube-dl for all sites
* An animated icon has been added in the status bar to indicate when the player
is buffering.
* A new layout is used to display the media information (Options -> View info and
properties).
Alles anzeigen
