LameXP v4.03 RC-1:
ZitatAlles anzeigenChanges between v4.02 and v4.03:
* Added an option to rename the output files (based on an user-defined naming pattern)
* Added an option to enforce Stereo Downmix for Multi-Channel sources
* Added "built-in" WMA decoder (see this thread for details) and removed all remnants of "old" decoder
* Added optional support for the FHG AAC Encoder included with Winamp 5.62 (see FAQ doc for details)
* Added a menu for bookmarking "favorite" output folders to the "output folder" tab
* Added an option to hibernate the computer (aka "Suspend-to-Disk") instead of shutting it down
* Added Polish translation, thanks to Sir Daniel K <sir.daniel.k@gmail.com>
* Added channel equalization options to the normalization filter (also fixes multi-channel processing)
* Updated Qt runtime libraries to v4.8.0 RC-1 (2011-10-13), compiled with MSVC 10.0
* Updated LAME encoder to v3.99 Final (2011-10-17), compiled with ICL 12.1.6 and MSVC 10.0 (details)
* Updated mpg123 decoder to v1.13.4 (2011-09-07), compiled with GCC 4.6.1
* Updated MediaInfo to v0.7.50 (2011-09-23), compiled with MSVC 10.0
* Updated language files (big thank-you to all contributors !!!)
* Improved "downmix" filter by using explicit channel mappings for each number of input channels
* Fixed a potential bug in CPU type detection that might have caused the wrong binary to be used
* Fixed Cue Sheet import for tracks with certain characters in the title
* Workaround for malicious "anti-virus" programs that prevent innocent applications from functioning
* Enabled "Aero Glass" theme in installer and web-update program (Vista and Windows 7 only)
* Restored Windows 2000 support with Visual Studio 2010 builds (this is experimental!)
* The "Open File(s)" and "Open Folder" dialogs will now remember the most recent directory
* Miscellaneous bugfixes
