LameXP 4.01
ZitatAlles anzeigen* Added an option to manually specify the number of parallel instances
* Added an option to select a user-defined TEMP directory
* Added an option to shutdown the computer as soon as all files are completed
* Added an option to add directories recursively
* Added support for *****ding cover artwork (currently works with LAME, FLAC and Nero AAC only)
* Updated Qt runtime libraries to v4.7.2
* Updated LAME encoder to v3.99.0.16 (2011-04-04), compiled with ICL 12.0.2
* Updated Vorbis encoder to v2.87 using aoTuV Beta-6.02 (2011-02-28), compiled with ICL 11.1 and MSVC 9.0
* Updated TTA decoder multiplatform library to v2.1 (2011-03-11), compiled with MSVC 9.0
* Updated SoX to v14.3.2 (2010-02-27), compiled with ICL 12.0.2
* Updated MediaInfo to v0.7.43 (2011-03-20), compiled with ICL 12.0.2 and MSVC 9.0
* Updated language files (big thank-you to all contributors !!!)
* Fixed a problem with the LAME encoder that could cause glitches (VBR mode), reported by Wolfgang Waldeck
* Fixed a problem with the LAME encoder that could cause very slow encoding speed
* Fixed a bug that caused AAC encoding to fail in CBR mode (the "-2pass" parameter was set wrongly)
* A warning message will be emitted, if diskspace drops below a critical limit while processing
