Ich benutze DVD2SVCD 1.1.3. build 2 und TMPEGENC 2.51.11. Beim Muxen erkennt das Programm den xxxx.mpg nicht, obwohl es schon in den gleichen Ordner drin war.Hab' ich was falsch gamacht??? Kann jemand von euch mir helfen? Danke euch im Voraus.
Hier ist mein Log.file:
ZitatAlles anzeigen
WNASPI32.DLL 4.6.0.1021
- 14.05.2003 20:30:34
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.1.3 build 2
Initializing
No subtitles found, skipping subtitle analyze
Initializing finished.--------------------------------------------------------
- 14.05.2003 20:30:38
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.INIVariable settings:
iDCT_Algorithm: IEEE-1180 ReferenceExecuting DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[C:\Programme\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[D:\DVD-FILME\Opa und Nichte\VTS_02_1.vob,D:\DVD-FILME\Opa und Nichte\VTS_02_2.vob,D:\DVD-FILME\Opa und Nichte\VTS_02_3.vob,D:\DVD-FILME\Opa und Nichte\VTS_02_4.vob]
Framerate: 25000
DVD2AVI processing done.--------------------------------------------------------
- 14.05.2003 20:34:53
- Free on drive C: 11592.93 mb
- AUDIO Extraction
Found MPA stream id: 0xC0
Filename: C:\Programme\DVD2SVCD\Movie\Extracted_audio_1.mpa
Audio1 delay: -80 ms
Audio extraction finished.--------------------------------------------------------
- 14.05.2003 20:41:17
- Free on drive C: 11483.45 mb
- AUDIO conversion
--------------------------------------------------------Encoding Audio. Filename: C:\Programme\DVD2SVCD\Movie\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"C:\Programme\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "C:\Programme\DVD2SVCD\Movie\Extracted_audio_1.mpa" -output "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.aif" -6chaiff -logfile "C:\PROGRA~1\DVD2SVCD\Movie\Encoded_audio_1.log" ) -ota( -g 6 -d -80 ) -shibatch( --rate 44100 )
Audio conversion of C:\Programme\DVD2SVCD\Movie\Extracted_audio_1.mpa finished.Executing MPEG51 Encoding. Commandline:
"C:\Programme\DVD2SVCD\MPEG5.1\pub_enc.exe" -l 2 -m s -n d -r 44.1 -b 384 -L -p 3 -e -v 0 "C:\Programme\DVD2SVCD\Movie\Encoded_audio_1.aif" "C:\Programme\DVD2SVCD\Movie\Encoded_audio_1"
MPEG 5.1 encoding of C:\Programme\DVD2SVCD\Movie\Encoded_audio_1.aif finished.Audio conversion finished.
- 14.05.2003 20:50:22
- Free on drive C: 10678.81 mb
- Converting Pictures
Converting: C:\Programme\DVD2SVCD\DefaultTitlepicture.bmp
Converting: C:\Programme\DVD2SVCD\DefaultChangeCD.bmp
Converting: C:\Programme\DVD2SVCD\DefaultLastCD.bmp
Finished converting pictures
- 14.05.2003 20:50:33
- Free on drive C: 10677.68 mb
- Video Encoding using TMPGEnc
- Encoding C:\Programme\DVD2SVCD\Movie\TitlePicture.bmp.avs
Executing TMPGEnc. Commandline:
"C:\Programme\Pegasys Inc\TMPGEnc Plus 2.5\TMPGEnc.exe" "C:\Programme\DVD2SVCD\Movie\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.- Encoding C:\Programme\DVD2SVCD\Movie\ChangeCDPicture.bmp.avs
Video Encoding finished.- Encoding C:\Programme\DVD2SVCD\Movie\LastCDPicture.bmp.avs
Video Encoding finished.- Encoding Test Clip C:\Programme\DVD2SVCD\Movie\AviSynth_Script_file_CQ_TEST.avs
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 150.00
Calculated next CQ Value: 146.96
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 146.96
Calculated next CQ Value: 143.98
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 143.98
Calculated next CQ Value: 141.06
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 141.06
Calculated next CQ Value: 138.20
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 138.20
Calculated next CQ Value: 135.39
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 135.39
Calculated next CQ Value: 132.65
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 132.65
Calculated next CQ Value: 129.96
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 129.96
Calculated next CQ Value: 127.32
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 127.32
Calculated next CQ Value: 124.74
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 124.74
Calculated next CQ Value: 122.21
Wanted: 1401578272 (1368729kb) Predicted: 1448960417 (1415000kb) Using CQ Value: 122.21
Final CQ Value: 122.21
- Encoding C:\Programme\DVD2SVCD\Movie\AviSynth_Script_file.avs
StreamSectors: 1663691176
AudioSectors: 233004240
VideoPAPO: 22162104
ScanOffsetBytes: 107606
SeqAligningBytes: 6838946
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 900.00
PureMPEGStream: 1401578271.80
Seconds: 4789.48
CalcMPEGStream: 1401578271.80
Frames: 119562
CDSize: 800.00
Number of CDs: 2
Cut point 795.00
Using CQ Value: 100.00
Aspect Ratio: 4:3 (No borders, encoded as 4:3)---AVS Begin---
Import("C:\PROGRA~1\DVD2SVCD\Movie\RESAMP~1.AVS")
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1\Mpeg2dec\mpeg2dec.dll")
mpeg2source("C:\PROGRA~1\DVD2SVCD\Movie\DVD2AV~1.D2V")
BicubicResize(480,576,0.0,0.6)
----AVS End----Executing TMPGEnc. Commandline:
Video Encoding finished.--------------------------------------------------------
- 15.05.2003 06:16:43
- Free on drive C: 9209.93 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Programme\DVD2SVCD\bbMPEG\default.iniExecuting RunbbMPEG. Commandline:
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Programme\DVD2SVCD\Movie\TitlePicture.bmp.mpg"
- 15.05.2003 06:16:48
- Free on drive C: 9209.89 mb
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Programme\DVD2SVCD\Movie\ChangeCDPicture.bmp.mpg"
- 15.05.2003 06:16:52
- Free on drive C: 9209.87 mb
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Programme\DVD2SVCD\Movie\LastCDPicture.bmp.mpg"
- 15.05.2003 06:16:56
- Free on drive C: 9209.84 mb
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 795 mbExecuting RunbbMPEG. Commandline:
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "C:\Programme\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg"
- 15.05.2003 13:44:40
Initializing
- 15.05.2003 13:44:45
- Free on drive C: 9209.67 mb
- Crash Recovery
- Restarting from: Muxing and Cutting
- 15.05.2003 13:44:47
- 15.05.2003 13:44:51
- 15.05.2003 13:44:55
- 15.05.2003 13:44:59
Executing bbMPEG.
Variable Settings:
