ffmpeg version 0.4.9-pre1, build 4723, Copyright (c) 2000-2004 Fabrice Bellard
built on Oct 20 2004 18:37:34, gcc: 3.2.3 (mingw special 20030504-1)
Input #0, mpeg, from 'jojo3.mpg':
Duration: 02:47:58.4, bitrate: 564 kb/s
Stream #0.0: Video: mpeg1video, 352x288, 25.00 fps
Stream #0.1: Audio: mp2, 44100 Hz, stereo, 128 kb/s
Must supply at least one output file
++ WARN: APS' pts seems out of order (actual pts 9703.484211, last seen pts 9703
.524211) -- ignoring this aps
<mpeg-info src="jojo3.mpg">
<mpeg-properties>
<version>1</version>
<playing-time>10081.920000</playing-time>
<pts-offset>0.284211</pts-offset>
<packets>306037</packets>
<bit-rate>0</bit-rate>
<video-stream index="0">
<!-- motion video stream -->
<horizontal-size>352</horizontal-size>
<vertical-size>288</vertical-size>
<frame-rate>25.000000</frame-rate>
<bit-rate>104857200</bit-rate>
</video-stream>
<audio-stream index="0">
<!-- base audio stream -->
<layer>2</layer>
<sampling-frequency>44100</sampling-frequency>
<bit-rate>131072</bit-rate>
<mode>stereo</mode>
</audio-stream>
</mpeg-properties>
</mpeg-info>
so das steht da drinn
und der Untertitell ist ein Text ist eine *.sub datei
