[font=verdana, arial, helvetica]Hallo zusammen,
von DVX gibt's mal wieder eine neue Version. Bei der Gelegenheit möcht ich auch gleich fragen ob jemand Lust hat bei der Hilfe zu helfen insbesondere bei der [/font][font=verdana, arial, helvetica]deutschen [/font][font=verdana, arial, helvetica]Übersetzung
3.56b
-----new features-----
the AviSynth menu in the main dialog modifies only special regions in the AviSynth script. A region looks like this:
#Resize
code here generated by the menu
#End Resize
the benefit is the script can be modified manually and after that still be changed with the menu without loosing the manuall changes if they are outside of the menu regions. The other benefit is the filter order can be changed by moving the regions. Like in previous versions menu items can be changed with Ctrl+Leftclick, additionally it's now possible to edit the menu in the settings dialog including moving and renaming categories
-----improved features-----
protection about subtitle mixer preventing DVX to open files
-----fixed bugs------
[/font]
[font=verdana, arial, helvetica] subtitle language tags were broke because recent changes in VirtualDubMod[/font]
bitrate for VP 6
-----reseted settings-----
AviSynth menu in main dialog, AviSynth scripts in profiles/projects, codec settings
http://www.planetdvb.net/dvx[/font]
