seit ein paar Tagen ist XMPEG 5.0 RC1 verfügbar auf MP3Guest
Ich war mit der beta2 schon relativ zufrieden.
Changes XMPEG 5.0 RC1:
-Support for titles/chapters
-Support for interlaced output frames (Compatibility with LSX)
-Old resampler replaced by a based on bessel algorithm resampler (SSE2 optimized).
-More accurate scene selection (Use set Job start/end, play/+/-/ to select exaclty the picture where to begin).
-Better synchronization Audio/Video at start. No more frame repetitions or unexpected first frame.
-Support for multifile open. Waiting that scenes can be writed in the same file, you can now select multiple sources to encode.
-Audio now stops at real end of the stream (not before). This bug has been discovered when implementing equal stream lenght in AVIWriter.
-Better premiere emulation.
-Possibilty to open multiple file for the future XMPEG project system.
-Lot of new features.
-Lot of deadlock removed.
-Lot of Bug fixed.
Fixed :
-Fixed Wav/MP3/AC3 extraction bugs (Stream selection, file closed correctly, no fancy crashes).
-Fixed RGB32/YUY2 was unusable after optimization. (Bug from 5.0 beta2, sorry...)
-Fixed Auto selection format bug. Sometimes, even if autoselect is checked, the format used is not the better.
-Fixed : When scene selection is changing, audio continues.
-Fixed : When scene selection has changed, and push play, Xmpeg crash.
-Fixed : Windows sometimes disapear back to player window, or main window stays background.
-Fixed : Player blocks if you put Scene End/Start markers out of bounds.
Known issues:
-Angles are not properly shown.
-Multiple file opening is fragile...
AVIWriter
-Changes in graphical interface.
-Watermark enabled. Transparent color is 255/0/255 (Standart)
-Can be now used with Premiere 5.0 and +
