[font=verdana,arial,helvetica] [/font]http://www.planetdvb.net/dvx/fd/[font=verdana, arial, helvetica]Ich hoffe die neue Version macht keine Probleme, zu finden hier: [/font][font=verdana, arial, helvetica]http://www.planetdvb.net/dvx/fd/[/font]
4.02b
[font=verdana, arial, helvetica] the AviSynth filter definitions are now included to keep the AviSynth plugin dir clean, to not change anything outside the DVX dir, to have all things that are not third party to be included
changed the defaults for file associations mainly removed everything to not polute the system
updated program detection and recommendation to XviD 1.0.1 and BeSweet 1.5b28
added title option to mkvmerge
fixed bug with aspect ratio with mkvmerge
fixed bug with overhead with mkv and mp4
fixed a bug with named variables in the AviSynth source region
fixed bug where shutdown/standby didn't work
fixed bug where the processed jobs wasn't deleted from the joblist
job state (enabled/disabled) will no be saved
improved layout in the job window
improved enabled/disabled control states in the job dialog
added support for latest bsn in BeSweet GUI
the audio dialog has a new layout because the bsn GUI didn't fit in the old one
the AviSynth menu in the main dialog uses now different names as category name and as category region name because of problems with the translation. In the settings where the menu can be customized, the property grid used for this has now help text for all properties. The menu settings and the scripts of course had to be reseted.
improved assistent tips for mp4 and mkv
Polish translation updated by Pablak
I didn't announce the previous version here so here is the changelog for that:
4.0beta1
-----new features-----
GUI support for the new bsn switches, please suggest a default profile. The required libraries will be copied if possible
the colorspace for DVD2AVI can be specified
double click in the preview switches between fullscreen/normal view, the window can be moved with the left mouse as well
added the possibility to jump to the previous or next range start or end in the preview, Ctrl + Up/Down is range jump now and chapter jump is now Shift + Up/Down by default
the plugins settings display the plugin version and the description will now be displayed as well for plugins that are not loaded and it will be displayed if a plugin is loaded or not, old plugins will failed to load and have to be removed from the plugin dir if a error message pops up, recompiled plugins are included
new plugin called Windows Media Native, it creates native Windows Media WMV files, note: DVX can also create avi, mkv and ogm files with Windows Media 9 codec. The plugin requires Windows Media Encoder 9 to be installed. Cutting is not supported
the plugin editor uses now like the AviSynth editor the SharpDevelop text editor control so there is syntax highlighting
support for image based subtitles using vsrip and mkvmerge, support to set the aspect ratio flag with mkvmerge to avoid resizing, the order of the subtitles can be changed via context menu
added the possibility to encode with VirtualDub instead of VirtualDubMod, the DVX audio profiles are not compatible with VirtualDub but VirtualDub is very limited anyway. If mkvmerge is enabled the VirtualDub/Mod scripts audio processing/muxing scripts won't be processed. As usual the assistent should give a notice about incompatible settings
The AviSynth script editor has a new version of the text editor control with various changes like line numbers, selecting lines when the cursor is on the left side. It scrolls now with the mouse selection.
added additionally to shutdown a standby option
added advanced setting to restrain the standby or shutdown if a given program is running for instance a DVB application records a schedule
renamed BeSweet settings to "Command" and added the possibility to add multible lines which will then be processed as batch
added support for MP4 container using the 3ivx DirectShow filter
-----improved features-----
the paths to the programs can be changed even if the proper version is already selected
the advanced settings and advanced options have a translated and better interface
the assistent options have been moved from the advanced options to a own settings page
the demuxing settings for avi are separated from the demuxing settings for mpeg2
replaced the hybrid option with a fast deinterlace option in the main dialog
changing the size by selecting a compressibility percent value is now precise so the assistenr won't complain
opening a audio file with no audio settings won't calculate the size of the file any longer but there is a new profile for calculating the size only
the program verification before the encoding will only check programs that will be actually used in the process
-----fixed bugs-----
AviSynth profiles weren't saved
the preview/crop crashed on systems with 16 bit resolutions
radio check wasn't displayed for the codec menu items
DVX reseted decoder settings for XviD and DivX in previous versions because the codecs save the encoder and decoder settings in the same registry key and DVX saves and retrieves the entire registry key. Decoder settings will now be ignored for XviD and DivX
chapter data wasn't passed to VirtualDubMod for mkv files (it's recommend to use the mkvmerge plugin for mkv files)
warning about comma in filepath wasn't shown in all cases (not supported by the DVD2AVI CLI)
-----notes-----
internally wide parts were reimplemented to have a better foundation for future improvements, because of this program and project settings saved with prior versions can't be reused[/font]
