Optimierer für ein besseres Ergebnis mit DVD RB.
Changelog:
- Added support to OPV.
DVD-RB's OPV prediction pass is done at the end of the prepare phase,
this makes it impossible to use RB-Opt with DVD-RB's version of OPV.
The prediction has already been run using the default CCE settings
from DVD-RB, and any changes to those (e.g. by selecting a custom
matrix with RB-Opt, or changing the GOP length) will invalidate the
results and cause an under- or over-sized encode. By doing the
prediction in RB-Opt one is able to set custom parameters and tweaks
as usual and *then* run the OPV prediction, meaning the prediction
will be run with the same CCE parameters as the actual encode, and
should thus be accurate.
More info can be found in OPVreadme.txt in the package.
Now you can run the "prepare" step in DVD-RB using normal VBR mode,
then, in RB-Opt, select for any VobID if encode in VBR or OPV mode.
If you have an oversized (or undersized) result in OPV mode, you can
re-open the Rebuilder.inf in RB-Opt, and change the mode to VBR. After
saving, the "encode" step in DVD-RB will run just the second CCE pass
(as the .vaf file is retained).
- Fixed a bug: if you selected a non standard matrix in CCE options, it
was used not only for the selected per vob-id, but for the whole film.
Now you can set different matrices for every VobID (ex. use a low
bitrate matrix for extras with low bitrates, leaving default matrices
for the main movie)
Download : klick
