ZitatAlles anzeigen
I decided these changes were important enought to post in a maintenance version. Below is a summary of the changes/updates associated with this version:
- Found and fixed a source of Error code '9' that can occur immediately at the start of an encode.
- Made changes to the output ECL formats so CCE SP version 2.67.xx.xx retail versions are supported. Please note that SP 2.67.xx.xx Trial version will only work with ECLCCE.EXE. Do NOT attempt to use ECLCCE.EXE with the retail version of 2.67.xx.xx -- it isn't needed, and doesn't work. Note: I don't have a copy of the retail version to test -- but I believe it will work.
- Found and fixed an error in which certain circumstances could cause illegal System Clock Reference (SCR) values near the end of some cells. This could very possibly have caused audio problems and/or video problems on some standalone units. Special thanks to Sir Didymus for identifying this problem.
Download wie immer hier.
