ZitatAlles anzeigen
Von: Klaus Schmidinger
An: ML
Datum: Heute 17:39:20
VDR developer version 1.3.16 is now available at
ftp://ftp.cadsoft.de/vdr/Developer/vdr-1.3.16.tar.bz2
*** NOTE THAT THE WARNINGS REGARDING THE USE OF VPS CONTROLLED
*** TIMERS FROM PREVIOUS RELEASE NOTES STILL APPLY!
The changes since version 1.3.15:
- Fixed cChannel::SetName() in case only the ShortName or Provider has changed
(thanks to Sascha Volkenandt for reporting this one).
- Added Danish language texts (thanks to Mogens Elneff).
- Reactivated the NPTL check at startup because there appear to be still
unsolved problems when running on NPTL systems.
- Added missing calls to cStatus::MsgOsdClear() in cSkins::Message() (thanks
to Joachim Wilke for reporting this one, and Andreas Regel for additional
input).
- Fixed the cDvbSpuDecoder (thanks to Marco Schlüßler).
- Fixed handling of pmAudioOnlyBlack (thanks to Stefan Huelswitt).
- Fixed a short glitch when starting a recording on the primary device while
in replay or transfer mode (thanks to Marco Schlüßler).
- Added missing initialization of cEvent::seen.
- Checking PID language codes for ISO 639 compliance to avoid problems with
funny characters. Invalid language codes will be stored as "???".
- The '0' key now toggles the "Day" item in the "Timers" menu between "single
shot" and "repeating". The keys '1'...'7' can be used to toggle the individual
days ('1' is monday). Thanks to Sascha Klek for reporting a problem with the
'0' key in the "Day" item of the "Timers" menu.
Have fun!
Klaus
Quelle: vdr mailinglist
