Frohe Weihnachten.
Soeben checkte ich mein Postfach und siehe da eine neue DVD-RB Version.
Änderungen:
Changes in this version:
- Added a new option entitled "No Compression (100% Video)" under the "Mode" menu. This option will keep original video intact (no reencoding) and only remove audio/subtitles as selected. This is meant for use with discs that are only slightly over DVD-5 size and can fit with audio removal. It is also a way in which previously created discs can be demuxed and remuxed to fix possible errors (for example buffer overflows or audio dropouts). This mode is very, very fast.
- The default skin "Rockas Original" was completely reworked and is now even
more cool than previously. My thanks to Rockas. Make sure to select "Rewrite Defaults" under the "Skins" menu for the fix to take effect.
- Modified the One Pass VBR (OPV) prediction code to more accurately select Q values. The previous method tended to make output too small. Thanks to Robot1 for lending me his code to analyze.
- Added a new default skin called "Simple Blue" It takes advantage of the
standard background provided by Rockas. In order for this skin to be
available you must select "Rewrite Defaults" under the "Skins" menu.
- Fixed a "disappearing button" problem associated with the Batch "OK" button
- Fixed an error in which changing skins while processing batch jobs could lock out the possibility of interrupting the program -- essentially locking out the user.
