GNOME 2.17.2 Development Series
Linux News
09.11.2006
Mono 1.2 kommt heute
Freie .Net-Implementierung unterstützt das Windows Forms API
http://www.golem.de/0611/48845.htmlOffenes Linux-Smartphone »OpenMoko« für Januar 2007 angekündigt
http://www.pro-linux.de/news/2006/10448.htmlSun und Ubuntu erweitern Kooperation
http://www.heise.de/newsticker/meldung/80716 -
Debian GNU/Linux Etch RC1 (Debian-Installer)
Improvements in this release of the installer* This new version of the installer uses and installs the 2.6.17 kernel which is now the default for all architectures.
* The installer will now create ext3 partitions with important options like resize_inode and dir_index enabled by default; the first means that on-line resizing of ext3 partitions is supported.
* The 2.6.17 kernel should support installing from most CD-ROM/DVD drives in systems with a SATA controller. However, there are known issues in 2.6.17 with some controllers that have been fixed in 2.6.18.
* Guided partitioning now also supports setting up the system on an encrypted LVM partition.
* Because of the previous change, the user interface for guided partitioning was modified: users are now asked first for the type of guided partitioning to be done and next for the disk to be used. This change also affects preseeding 1).
* Improved support for fully automated installations 1).
* It is now possible to partition multiple disks with software RAID (levels 0, 1 and 5) using preseeding 1).
* When configuring the network using DHCP, the installer will send vendor-option-string "d-i". Using this the DHCP server can be set up to tell the installer which preconfiguration file to use 1).
* Because SELinux has been made standard priority, newly installed systems will have SELinux support. However, to actually use SELinux, this needs to be enabled manually after the installation.
* Architecture specific:
o i386: installation from floppy disk is supported again
o arm: the Linksys NSLU2 has switched to the generic ixp4xx kernel and now uses APEX as the 2nd stage boot loader; using APEX allows to work around the NSLU2's 1 MB kernel limit
o arm: support for the sub-architecture IOP32x has been added; the first device that is supported is the GLAN Tank
* Added the following languages (for the graphical installer only): Gujarati. -
16.11.2006
Linux New Media Awards 2006 vergebenZitatZu den Gewinnern des Jahres 2006 gehört die Distribution Ubuntu, die in zwei der sechs Kategorien ausgezeichnet wurde. Ubuntu erhielt den Preis für benutzerfreundlichste Distribution und deklassierte mit 27 Prozent die KDE-Konkurrenz Kubuntu (13 Prozent) und OpenSuse (11 Prozent).
http://www.pro-linux.de/news/2006/10480.htmlBitbone BitKit nun auch für Ubuntu
ZitatDazu gehören Lösungen für Datensicherung, Archivierung und Hochverfügbarkeit ebenso wie Produkte von Arkeia, Astaro, Kaspersky, Message Partners, NoMachine und anderen.
Firebird 2.0
http://www.pro-linux.de/news/2006/10463.htmlOxygenOffice Professional 2.0.4
ZitatOxygenOffice Professional ist eine erweiterte Version von OpenOffice.org 2.0.4..So enthält das Paket über 2900 freie Cliparts und Fotos. Von der integrierten Galerie können diese in Dokumente kopiert werden. Eine Sammlung von Vorlagen und mehr als 90 freie Schriften für den geschäftlichen und privaten Gebrauch ergänzen den Funktionsumfang. Zusätzliche Dokumentationen und Tools wie OOoWikipedia, das Begriffe in der freien Enzyklopädie nachschlägt, sind ebenfalls im Paket inbegriffen.
http://www.pro-linux.de/news/2006/10478.htmlLinux Mint 2.0: Ubuntu mit Multimedia-Codecs
http://www.golem.de/0611/48978.htmlSoftwarefehler: World of Warcraft schmeißt Linux-Nutzer raus
http://www.golem.de/0611/48983.html -
debian etch verspätet sich ca. um einen monat. deswegen kein debian etch zu nikolaus
quelle: ich :zunge:
tschicker guide für die leute die früher oder später mal ubuntu testen wollen
Erstes Linux für Playstation 3 fertig
ZitatEine Hardware-Beschleunigung ist weder in 2D, 3D noch für OpenGL möglich, was grafisch ansprechende Spiele auf der Linux-Oberfläche verhindert.
ZitatAndere Anwendungen wie OpenOffice, Internetbrowser oder E-Mail-Clients laufen aber ohne weiteres, soweit sie mit den 256 MByte Hauptspeicher der Playstation 3 auskommen
http://www.heise.de/newsticker/meldung/81254
Nix halbes und nix ganzes.......
Ubuntu plant "The Feisty Fawn"
Die nächste Version der Linux-Distribution strebt neben einer besseren
Hardware-Erkennung noch mehr Einsteigerfreundlichkeit an. -
Paldo Linux ist eine recht unbekannte Distribution. Seit gestern bin ich nun Maintainer für dieses Projekt. Durch meinen engen Kontakt zu den Projekt-Gründern versuche ich Paldo nun auch in Deutschland bekannter zu machen. Paldo ist eine schweizer Distribution, welche Deutsch und Englisch unterstützt. Unser Desktop ist Gnome. Die Projektseite findet Ihr hier. Ich hoffe ich sehe ein paar von Euch bald bei uns
27.11.2006
Amnon82
Herzlichen Glückwunsch zu paldo und alles gute für die Zukunft.
Ich hoffe sehr,das der Bereich Multimedia stark vertreten sein wird...
http://forum.gleitz.info/showpost.php?p=309388&postcount=1------
Kleiner weißer Riese
[Blockierte Grafik: http://www.pro-linux.de/NB2/images/indiv/k_wizpy02.jpg]
http://www.pro-linux.de/news/2006/10509.html
http://de.theinquirer.net/2006/11/27/der…_pinguin_d.htmlMark Shuttleworth umwirbt OpenSuse-Entwickler
http://www.pro-linux.de/news/2006/10527.htmlNicht ganz Linux,aber passend zum Thema :
Die INQ-Hitliste der fünf größten Fehler von Novell
http://de.theinquirer.net/2006/11/25/die…fuenf_groe.htmlEclipse on Linux kann Arbeit aufnehmen
http://www.golem.de/0611/49116.htmldyne:bolic - LiveCD für Multimediabastler
http://www.pro-linux.de/news/2006/10523.html -
Fotoverwaltung F-Spot 0.3.0 erschienen
Die Linux-Fotoverwaltung F-Spot ist in der Version 0.3.0 erschienen und bringt unter anderem Anpassungen für den Export zu Googles Picasa-Online-Alben mit. Neben der Anzeige beherrscht F-Spot auch einfache Bearbeitungsfunktionen. -
Linux-Kernel 2.6.19 freigegeben
Umfangreiche Änderungen..siehe
Quelle: http://www.pro-linux.de/news/2006/10543.html
http://www.heise.de/open/artikel/80823 -
Ulteo
Ulteo ist eine Ubuntu/Kubuntu-basierende Linuxdistribution von Gaël Duval, dem original Gründer von Mandrake Linux (nun Mandriva Linux) Und Co-Gründer von MandrakeSoft (nun Mandriva). Es ist im sehr frühen Entwicklungsstatus. Ulteo verspricht Linux-Anfänger kräftig unter die Arme zu greifen um Linux noch einfacher zu machen. Eine erste Alpha-Live-CD wird zum 06.12.06 online gehen. Somit kann man sich ein Bild von der neuen Distribution manchen. Es wird Deutsch, Englisch, Französisch und Italienisch von Anfang an unterstützt. Ich werd sie auf jeden mal downen und mir reinziehen
Kanotix
Jörg Schirottke, der Gründer von Kanotix wechselt die Debian-Unstable-Basis nach Ubuntu und wird seine Distribution mehr in den kommerziellen Bereich pushen. Stefan Lippers-Hollmann gefällt das garnicht und startet somit einen ReDesign von Kanotix unter dem Namen Sidux.
openSUSE
10.2 steht in den Startlöchern. "We've mastered yesterday openSUSE 10.2 RC5 and declared it as 'goldmaster'." Obwohl die "Stable" von 10.2 noch viele Fehler offen hat :ani_lol: wird die Distribution am 7.Dez. released. Suse ist bekannt für die "Einhaltung" der Roadmaps. Somit machen Sie schon Microdoof Konkurenz. Juli 2007 gibts dann wieder eine richtig stabile Version mir sehr vielen neuen Features (klar! Kommt Zeit, kommen neue Programme).
Ubuntu
Es scheint, dass die ganze Welt sich heut die erste Alpha CD von Feisty Fawn. Mein Download-Speed ist zwischen 60-80 KBs obwohl ich immer mit > 250 KBs downe. Es wird nun der 2.6.19er Kernel verwendet.
Die Primäränderungen gegenüber Edgy Eft sind das Re-Merging der Änderungen von Debian gewesen. Die komplette Release-Note könnt Ihr hier lesen. Nur die Alternate-CDs herrunterladen, da die Desktop-CDs bei den meisten Laptops im Installer abstürzen!!! -
22.12.2006
Linux User Group Backnang veröffentlicht Weihnachts-DVD tuXmas
http://www.pro-linux.de/news/2006/10647.html -
01.01.2007
Knoppix 5.1 freigegebenZitatFerner beinhaltet Knoppix 5.1 ntfs-3g (Stand: 12.12.2006) für eine volle Unterstützung von NTFS-Schreibzugriffen
08.01.2007
Installationsduell Windows XP gegen KUbuntu 6.10
http://www.pro-linux.de/berichte/wxp_kubuntu.htmlUpdate für Knoppix 5.1
http://www.heise.de/newsticker/meldung/83329Buch : Ubuntu GNU/Linux von Marcus Fischer
Grundlagen, Anwendung, Administration
Download : http://www.galileocomputing.de/openbook/ubuntu/ -
16.01.2006
Fluendo kündigt native Windows-Codecs für Linux und Solaris an
http://www.pro-linux.de/news/2007/10721.html
gleiches Thema
Native Windows-Codecs für Linux und Solaris
http://www.golem.de/0701/49970.htmlVirtualBox im Quelltext vorgestellt
http://www.pro-linux.de/news/2007/10715.html -
22.01.2007
Multimedia-Variante von Ubuntu geplantZitatUnter dem Namen »UbuntuStudio« plant Ubuntu eine neue Variante der Distribution herauszugeben, die sich voll und ganz Multimedia-Belangen widmen wird.
http://www.pro-linux.de/news/2007/10745.htmlUbuntuStudio
http://ubuntustudio.org/ -
[Blockierte Grafik: http://img376.imageshack.us/img376/7644/avsoutput167ho9.th.png] [Blockierte Grafik: http://img376.imageshack.us/img376/8477/avs3gtkmain187dr1.th.jpg] [Blockierte Grafik: http://img393.imageshack.us/img393/4337/avs3gtkinfo138xm9.th.png]
Info
Avisynth 3.0 ist sehr mächtiger Frameserver für Windows und Linux. Editieren und Bearbeiten von Videos können nun auch durch AVS-Scripts in Linux erledigt werden.
Es ist ein kompletter Rewrite von Avisynth 2.5 durch Bidoche (David Pierre).Avisynth 3.0 für Linux Homepage
____________________________________________________________
AVISynth 3.0 wird von folgenden Distros unterstützt:
- Gentoo
- Paldo GNU/Linux - How to install AVS - Wie man AVS installiert
