Beim Umwandeln von einem DV-AVI nach DivX bricht AutoGK immer ab.
Ich benutze die neueste Beta-Version.
Die log-Datei sieht wie folgt aus:
QuoteDisplay More[19.09.2005 21:45:04] AutoGK 2.17b
[19.09.2005 21:45:04] OS: WinXP (5.1.2600).2
[19.09.2005 21:45:04] Job started.
[19.09.2005 21:45:04] Input file: C:\Downloads\rallye02_05-08-31_14-14_type2.avi
[19.09.2005 21:45:04] Input codec: dvsd
[19.09.2005 21:45:04] Source duration: 5mn 50s
[19.09.2005 21:45:04] Output file: D:\rallye02_agk.avi
[19.09.2005 21:45:04] Output codec: DivX
[19.09.2005 21:45:04] Audio 1: 1024 Kbps PCM 2ch
[19.09.2005 21:45:04] Subtitles: none
[19.09.2005 21:45:04] Format: .AVI
[19.09.2005 21:45:04] Target size: 63Mb
[19.09.2005 21:45:04] Custom resolution settings: fixed width of 640 pixels
[19.09.2005 21:45:04] Custom audio settings: CBR MP3 with bitrate: 128Kbps
[19.09.2005 21:45:04] Standalone support enabled: ESS
[19.09.2005 21:45:04] Started encoding.
[19.09.2005 21:45:04] Source resolution: 720x576
[19.09.2005 21:45:04] Source fps: 25
[19.09.2005 21:45:04] Manual aspect ratio: 4:3
[19.09.2005 21:45:04] Analyzing source.
[19.09.2005 21:55:07] Source has percentage of interlacing in motion areas: 100,00
[19.09.2005 21:55:07] Source is considered to be interlaced.
[19.09.2005 21:55:07] Output will contain 8750 frames
[19.09.2005 21:55:07] Demuxing audio.
[19.09.2005 21:55:33] Normalizing audio.
[19.09.2005 21:55:34] Encoding audio.
[19.09.2005 21:55:54] Audio1 size: 5,601,600 bytes (5.34 Mb)
[19.09.2005 21:55:54] Overhead: 321,280 bytes (0.31 Mb)
[19.09.2005 21:55:54] Video size: 60,137,408 bytes (57.35 Mb)
[19.09.2005 21:55:54] Target bitrate is: 1375kbps
[19.09.2005 21:55:54] Running compressibility test.
[19.09.2005 21:55:54] Writing the following script to D:\agk_tmp\rallye02_agk_comptest.avs
LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE2.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\kerneldeint.dll")movie = DirectShowSource("C:\Downloads\rallye02_05-08-31_14-14_type2.avi",25).KillAudio()
movie = isRGB(movie) ? ConvertToYUY2(movie) : movie
cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0)
fixed_aspect = 1.06666666666667
c_width = width(cropclip)
c_height = round(height(cropclip) / fixed_aspect)
input_par = float(c_width)/float(c_height)
input_par = (input_par > 1.4)(input_par < 1.25) ? input_par : (4.0/3.0)
out_width = 640
out_height = round(float(out_width) / input_par)
hmod = out_height - (floor(out_height / 16 ) * 16)
out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
KernelDeInt(movie,order=0,sharp=true)
autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=0,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0)
LanczosResize(out_width,out_height)
RemoveGrain(mode=2)
SelectRangeEvery(61,14)
[19.09.2005 21:56:10] Duration was: 16 seconds
[19.09.2005 21:56:10] Speed was: 124,44 fps.
EXCEPTION: Cannot open file "D:\agk_tmp\frames.log". Das System kann die angegebene Datei nicht finden
[19.09.2005 21:56:10] Job finished. Total time: 11 minutes 6 seconds
Es liegt also daran, dass AutoGK die frames.log nicht findet.
Wie behebe kann ich das Problem beheben?
