ZitatMPEG-TS: random cases with full parsing of the file
Hui, dafür hat wohl jemand was gezahlt, weil das letzte Mal als ich in die Richtung gefragt hatte es noch hieß, dass ein KomplettParsen ein No-Go wäre.
MediaInfo v0.7.41
http://code.google.com/p/mulder/downl…25.zip&can=2&q=
(CLI, statisch gelinkt, x86/ICL11 und x64/MSVC9 Builds)
0.7.42
ZitatAlles anzeigen+ Armenian translation added
+ Belarusian, Ukrainian translations updated
+ AES3: bit depth of AES3, bit depth of compressed audio stream, endianess
+ Id3v2 and MP4 tags: better mapping with iTunes fields
+ Tags: removal of technical only fields
+ MPEG Video: intra_dc_precision information (in advanced mode)
+ MXF: detection of raw pictures
+ MXF: support of URL encoded locators
+ MXF: color subsampling
+ DXW format support
x #3171468, ADIF: crash in some cases
x #3169916, IFO: crash in some cases
x #3173391, Id3v2: was using local encoding instead of ISO-8859-1
x MPEG Video, discarding bad (always 0) group_start
x AVC: crash with file having big log2_max_pic_order_cnt_lsb_minus4 value
x AVC: wrong GOP information in some cases
x Ut Video: Color space information was wrong
x MPEG-4 Visual: Advanced Simple@L0 was detected as Advanced Simple@L1
x AVI: Crash with some AVC streams (not sized blocks)
x MPEG Audio: crash with some files
x AAC: crash, infinite loop or wrong result with some files
x Trying to quicker reject a junk file
x AVI: OpenDML indexes were no more parsed
x Windows installer: OpenCandy library is updated and Microsoft agrees it is not dangerous for user privacy, it does not alert anymore. We do not transmit or collect personally identifiable information.
MediaInfo v0.7.42:
http://code.google.com/p/mulder/downl…11-03-05.zip&q=
(CLI, statisch gelinkt)
MediaInfo v0.7.43:
http://code.google.com/p/mulder/downl…23.zip&can=2&q=
ZitatAlles anzeigenVersion 0.7.43, 2011-03-19
+ MPEG-TS: detection and display of real time PAT/PMT change improved
x EIA-708: crash with some specific files
x MP4: crash with wiles including mix of PCM and other audio formats
x AAC: crash with some malformed streams
x FLV: crash with some specific files (longer audio than video at the end of the file)
x MP4: wrong framerate information with some specific files (track header after media information)
0.7.44
ZitatAlles anzeigen+ Russian translation updated
+ AVI: support of some corrupted files (RIFF size set to 0)
+ AC-3: support of streams with 16-byte time stamp between frames
+ MPEG-TS: detecting wrong stream registration information and skipping it
+ NTSC: accepting 483-line streams as NTSC
+ MXF: Parsing speed improvement, especially for high bitrate (>300 Mbps) streams
+ TGA file basic support
+ libmms: MMSH support (Linux/Mac only), thanks to RGB Networks
+ libcurl: HTTP header option and Time to live, thanks to RGB Networks
+ TIFF: more details
x MXF: some specific files were not analyzed, fix sponsored by http://maxnine.com
x LXF: random crashes
MediaInfo v0.7.44:
http://code.google.com/p/mulder/downl…22.zip&can=2&q=
(CLI, statisch gelinkt, x86 + x64, MSVC2010/ICL12)
MediaInfo v0.7.45 Beta:
http://code.google.com/p/mulder/downl…02.zip&can=2&q=
Diese Version behebt einen Fehler (Regression in v0.7.44) bei der Text-Ausgabe auf der Konsole (siehe auch).
0.7.45
ZitatAlles anzeigen+ Belarusian translation updated
+ QuickTime: Support of EIA-608 streams created by Final Cut
+ Matroska: Support of Matroska tags
+ Matroska: parsing of tags at the end of the file (previously: only tags at the beginning)
+ MP4/MOV with uncompressed streams: scan type (interlaced/progressive)
+ YUV4MPEG2 (Y4M) support
+ GXF: more information about AES3 audio streams
+ EXR: Basic support
+ E-AC-3: dialnorm/dynrng (first frame / first block) information
+ LXF: support of DV PAL
+ DPX: Support of Cineon old format
+ DPX: Support of file with Little Endian configuration
+ MPEG-4: better support of file with more than one mdat or moov atom
+ WAV: more details from bext chunk
+ MXF: AFD (in both descriptor or ANC) support
+ MXF: Support of AES3 / Dolby E in 2 mono channels
+ MPEG-4: support of some malformed (without mdat atom) files
+ MXF: Better detection of streams without Essence Compression descriptor
x MPEG Video: Custom matrix detection was broken
x DPX: Industry specific header was not well decoded
x JPEG-2000: Chroma subsampling 4:2:0 was recognized as 4:4:4.
x Matroska: Handling default values for TrackVideoDisplayWidth and TrackVideoDisplayHeight
x MPEG-TS: private audio streams with 0xCO stream_id were not correctly detected
x FLV and RIFF: Changing Sorenson H.263 to Sorenson Spark because this stream format is too much incompatible with H.263
x MXF: Some specific files (including AFD in descriptor) were not well parsed
MediaInfo v0.7.46:
http://code.google.com/p/mulder/downl…14.zip&can=2&q=
(CLI, statisch gelinkt, x86 + x64 Builds, MSVC2010)
ZitatAlles anzeigenVersion 0.7.46, 2011-07-04
+ MXF: TrackName
+ DCP: Basic support (video and audio streams), both Interop and SMPTE versions
+ P2 Clip: Supporting directories with wrong letter case
+ MXF: detection of AES3/Dolby E in mono PCM streams without compression scheme
+ MP4: first frame duration difference if first frame has not the same duration than all other frames
+ MP4: frame rate set as CFR if only the first frame has a different duration
+ MP4: Handling of track duration smaller than media duration (track duration and stream size have priority)
+ #3348936, MXF: OP-Atom profile
+ Matroska, Stereo Layout support, thanks to Lionel Duchateau
x libcurl (FTP/HTTP): seek request was buggy, invalid data was read
x MPEG Video in MPEG-TS or MP4: streams were wrongly detected as VBR or CBR, any bit rate mode is removed until a working solution is found
x AES (S302M): was no more detected if the packet was split in several PES
x #3325235, Vorbis: streams were wrongly reported as CBR
x EXR: Width/Height were 1 less than real value
x #3344635, MP4/MOV: Delay missing if timecode track found before audio/video, thanks to Peter Chapman
0.7.47
ZitatAlles anzeigen+ ISM (ISM/ISMV/ISMA/PIFF...) support
+ SCC (Scenarist Closed Captioning) support
+ #3201768, BMP: BitmapV4Header support, thanks to Lionel Duchateau
+ MP4: enda atom support (Endianess)
+ MXF: expliciting PCM endianess
x #3354384, Vorbis in AVI, version 3+ was displayed as 2+
x MPEG-4/MOV: files with big "free" atom were not parsed
MediaInfo CLI v0.7.47
http://code.google.com/p/mulder/downl…27.zip&can=2&q=
Static Build, MSVC 10.0, 32-Bit und 64-Bit
0.7.48
+ ISM (ISM/ISMV/ISMA/PIFF...): more attributes (frame rate, frame count, duration)
+ MP3: support of VBRI header in a corrupted frame
+ Active Format Description: muxing mode (A/35 or SMPTE ST 2016-3)
+ MP4/MOV: Displaying info about first description atom of a track (instead of all of them)
x MP4/MOV: scan order (Top/Bottom) from container, thanks to Peter Chapman
x MP4: Channel layout was not filled in some cases
x libmms: default behavior is using official libmms API only
x Vorbis comment: album performer data was in performer field
x Captions in AVC: some captions were not detected and decoded
x AVC: GOP structure info was often wrong
x MXF: IndexTable search was buggy (parsing the whole file) for some rare files (index present twice)
MediaInfo CLI v0.7.48
http://code.google.com/p/mulder/downl…17.zip&can=2&q=
Static Build, MSVC 10.0, 32-Bit und 64-Bit, Windows 2000 Fix
0.7.49
ZitatAlles anzeigen
+ AES3: analyzing AAC, AC-3, MPEG Audio *****ded in AES3 stream
+ GXF: detection of DolbyE in AES3 in GXF
+ WAV: detecting AES3 non-PCM audio inside WAV
+ MPEG Video: more precise duration for 29.97 fps material having time code without drop frame flag set
+ MPEG-4/MOV: delay from time code track conforming to Final cut (using integral frame rate value if frame drop flag is not set)
+ Overall bit rate mode (CBR or VBR)
+ DVB Subtitle: region_horizontal_address / region_vertical_address (hidden by default)
+ MPEG-TS: option (--ParseSpeed=0.8) for testing the stream until all advertised streams are detected
x MXF: some files with SDTI were not well demuxed (frame number) or were crashing
x Some files where wrongly detected as MPEG-PS without streams
x AC-3: non-48 KHz streams were not analyzed
x 3164893, JPEG: issue with some JPEG files with no/incorrect extention
x 3403338, crash with four character filenames
MediaInfo CLI v0.7.49
0.7.50
ZitatAlles anzeigen
+ Ukrainian translation updated
+ DVB Subtitle: region_width / region_height / region_depth (hidden by default)
+ MPEG-4: hdv6 and mx4p CodecID support (MPEG Video)
+ AVI: v210 CodecID (YUV) detect
+ #3411596, CDDA support, thanks to Lionel Duchateau
+ MXF: support of AC-3
+ #3411999, AVi: detection of GeoVision MPEG-4, thanks to Lionel Duchateau
+ #3411999, MPEG-4: detection of VC-1 (WMV3), Nellymoser and WMA2, thanks to Lionel Duchateau
x AVI: Better support of 2 video streams (e.g. "3D AVI") in a file
x MPEG-TS: Duration was not provided in some cases
x FLV: Delay and duration for AAC was wrong if delay was not 0, thanks to Justin Greer http://zencoder.com
x #3408005, IFO: crash with some files
x MPEG-4: some bitrates where wrong if smooth streaming is used
MediaInfo CLI v0.7.50
http://code.google.com/p/mulder/downl…24.zip&can=2&q=
0.7.51
ZitatAlles anzeigen
+ #2872918, MKV: add support for default and forced track flags
+ #3418881, RK Audio format support, thanks to Lionel Duchateau
+ #3418883, LA: version field, thanks to Lionel Duchateau
+ MPEG-4: basic support of Aigo .3dv files
+ MPEG-2 Video: color display info (colour_primaries, transfer_characteristics, matrix_coefficients)
+ QuickTime: color display info (colour_primaries, transfer_characteristics, matrix_coefficients)
+ QuickTime: ProRes LT, Proxy, 4:4:4 profiles detection
+ QuickTime: mpeg CodecID support
+ Template inputs are now insensitive to carriage return kind (Windows rn, Mac r, Linux n)
+ MPEG-TS: Support of ISO 8859-2 in EPG
+ MPEG-4: more CodedIDs supported
+ GXF: more info about DV streams
+ GXF: Handling of files with more than 1 Time code
x #3414326, GXF: using only the first map chunk for duration calculation
x #3414513, Id3v2: was not able to extract covers with UTF-16 description
x #3417908, video from several files: crash if there is not enough place for the frame number
x #3433602, DVD-Video (IFO): Crash when scanning some malformed IFO files
x Matroska: parser hanging in case of huge zero-padded files
x MPEG-4: was not providing some info about tracks with sample table before media header
x MXF: better support of corrupted indexes
x #3429831, MediaInfo library: unload wrong DLL, thanks to McSpecky
x MPEG-TS: Better handling of EPG running_status flag
x MXF: Handling of "file:///" in Network loacators
x FLV: audio delay was sometimes wrong
x H264: Buffer size was in bytes instead of bits like with other formats
x #3429196: no output if absolute file name, on Linux
x #3187050, FLV: wrong detection when FLV header is corrupt
x BLu-ray: crash if MPLS files are on the root of a disk
x Blu-ray: parsing was very slow if MPLS was pointing thousands of times on the same file
x #3292830, Matroska: crash if AAC sample rate is not provided by the container
MediaInfo CLI v0.7.51
http://code.google.com/p/mulder/downl…12.zip&can=2&q=
Static Build, MSVC 10.0 + ICL 12.1, 32-Bit und 64-Bit, Windows 2000 Fix
