Zitat:
>> Gordian Knot 0.27 supports AVI input (but it's experimental at the moment,
>> finally has 100% correct pixel-aspect ration values,
>> it allows you to edit a script manually before doing a comp-check,
>> fast deinterlace uses a more powerful method of deinterlacing,
>> in the options you can specify an alternative for mpeg2dec.dll (that allows you to use the P4 optimized DVD2AVI and the required mpeg2dec.dll),
>> the BeSweet commandlines have been updated and there have been some cosmetic improvements.
>> Now GKnot comes in two packages, the RipPack which contains the main program, the documentation, DVDDecrypter 3.1.4.0 (which replaces SmartRipper), vStrip 0.8d CSS,
>> DVD2AVI 1.76, BeSweet 1.5b8, all AviSynth plugins, VDub 1.4.13 and Nandub 1.0RC2.
>> Then there's the System pack which includes AviSynth 2.07, Huffyuv 0.2.2.1 (CCE-Patch), DivX3.11alpha, DivX5.02, VobSub 2.23 and all required audio playback filters
>> (AC3Filter, mpgaudio.ax and the Morgan Stream Switcher).
>> And then there's an executable only distribution.
Tja, was soll ich da noch sagen... Außer vielleicht https://localhost/www.doom9.org!
