:O ja, ja, ja
Das nächste versuche ich erst das Gehirn einzuschalten. Müßte ja wenn überhaupt erst mal ne 1.1.1 kommen bei VCD2SVCD
Aber trotzdem was gibts neues bei VCDEasy?
Blacky
:O ja, ja, ja
Blacky
Hallo Blacky113,
die Neuerungen kannst du hier lesen VCDEasy Hier ein kleiner Auszug
ZitatAlles anzeigen2003-01-21 - VCDEasy v1.1.4
Load/Save is not yet finished, but I prefer to publish VCDEasy 1.1.4 now, without the load/save yet, because a lot of bugs around the Media Player have been fixed, and the Nero ASPI support may help a lot of people having CD writer detection problems.
Better recognition of the Adaptec ASPI version if any
VCDEasy can now use Nero's ASPI layer if there ("WnAspi32.Dll" in the folder of Nero [and also
'NeroApix.vxd' in 'Windows\System\IOSUBSYS\' on Win9x/Me])
If you know what you are doing... you can force the use of a specific ASPI layer in putting the
corresponding "WnAspi32.Dll" file in the CDRDAO folder. Note that an ASPI layer may be more than just one file, so be careful to have all of them installed...
Several bugs/improvements related to the Media Player box (in the chapters page) has been fixed/
made. It should be more robust now. In theory, VCDEasy should be able to read what the Windows Media Player 6.4 (located at: "C:\Program Files\Windows Media Player\mplayer2.exe") can read... But, according to some users, it is not always the case... It depends in fact on the codecs (DirectShow filters in fact) your Media Player is using. Also, note that if your Windows Media Player is unable to resize a video under their original size (because of the codecs), then you may have sound but no video in the VCDEasy's Media Player.
A bug fixed in the display when Windows large fonts (yet another one...)
I removed the About, History and Credits pages, and replaced them by dialog windows accessiblevia the "Help" menu.
Außerdem hat sich das Aussehen etwas verändert sieht jetzt etwas nobler aus.
Hallo Blacky113,
wenn Morpheus nicht schon geantwortet hätte, hätte ich 20 min später geantwortet.
Die Option "Don`t make Image" sagt es ja schon, das es keine Images gibt. Wenn Du noch nichts gelöscht hast, geht Du im Register "Misc" auf "Recover" und lädst die DVD2SCVD Projektdatei. Anschließend im Register "CD Image" "VCDxBuild" auswählen und im Register "Misc" auf "Continue" klicken. Dann bekommst Du Deine Images.
Die Kapitel werden ebenfalls im Register "CD Image" eingestellt. Standard sind eigentlich die Kapitel der DVD eingestellt. Du kannst dann eine Zeit angeben, in deren Abstand dann Kapitelmarken gesetzt werden. Die musst Du natürlich einstellen, bevor Du auf Continue klickst.
Auch meine Empfehlung zum Brennen lautet VCDEasy
Moin
Gesucht und gefunden, ist ein Klasse Board weiter so!
mfG Stele
