Version 2.0.9:
- Code folding at curly braces {}. May be improved later.
- added an option 'show tabs in multiline style' in 'Options|Program settings|Misc'
- added "copy as time" to the frame number text box
- added an option "Don't preview when loading a session" in 'Options|Program settings|Video 1'
- if 'paranoia' mode turned on, don't preview when loading a session
- 'Save bookmarks to images' macro updated to support more image formats besides just bmp
- Many bugfixes:
fix: when closing a tab, always hid the preview window.
fix: the framenum parameter of avsp.SaveImage() doesn't work
fix: autocompletion doesn't apply customized preset if only typing a short name of a plugin filter
fix: resolution not mod 4 or odd(rgb), the image is skewed. a regression on avspmod 2.0.8 only.
fix: sometimes scripts line end is only 'LF'. force using windows style 'CR'+'LF'.
fix: can't enter funtion definition dialog if delete a filter but keep its preset.
fix: options.dat compatibility broken if user define a user funtion which name is short and is the same as the 2nd part of a long name filter.
fix: ESC shortcut doesn't work in wx2.8 or later.
Abilities of new code folding feature:
1. Click on fold marker or through menu "Edit|Toggle current fold" to show/hide lines.
2. Click on fold margin while holding Ctrl+Shift or through menu "Edit|Toggle all folds" to show/hide lines at all fold point.
3. Click on fold marker while holding Ctrl to toggle recursively.
4. Click on fold marker while holding Shift to toggle folds of child.
