Seit einigen Tagen ist eine neue Version von DVD Decypter erhältlich.
DVD Decrypter 3.1.5.0 (09/04/2003)
- Improved detection of currently inserted media
- Improved IFO/BUP file region patching code
- Improved RCE Protection detection in IFO mode
- Improved support for DVD+R/+RW drives
- Improved error reporting
- Improved drive region changing interface
- Improved I/O Interface 'Debug Mode'
- Improved device / disc information given in ISO modes
- Improved SPTI drive detection code in NT 4.0
- Improved Vob ID file splitting in IFO mode
Improved CSS cracking code - Added the ability to split by Vob ID in File mode
- Added the ability to create MDS files for most image types. These can then be loaded into DAEMON Tools
- Added the ability write several other types of images
- Added the ability to change the volume label of supported image files
- Added 'Maximum Write Speed' to the information window in ISO modes - For DVD media only
- Added the ability to create Information files by right clicking on a PGC in IFO mode
- Added the ability to patch the first GOP in an M2V stream so that the time is 00:00:00 instead of 00:59:59 or whatever - this allows chapter files to import directly within DVDMaestro and alike
- Added support for 'Success' and 'Error' sounds
- Added lots more user configurable options in the settings screen
- Added 'Shutdown computer when finished' to the ISO write screen
- Added the abilty to parse the ISO filesystem
- Added automatic detection of which filesystem to parse (UDF or ISO)
- Added automatic erasing / formatting of discs before burning
- More command line options - see Readme.txt
- Loads of other changes / fixes / requested features - too many to remember / mention!
Neue Version wird heute im Laufe des Tages in die Database aufgenommen.
