LOL, ich hab jetzt mal Audio auf "MP3 CBR 160" gesetzt jetzt fängt der Ton erst 4-5 Minuten später an, hab bei den F11 Settings rein garnichts geändert
Was ist denn da falsch gelaufen ?
ZitatAlles anzeigen[06.04.2007 17:38:42] AutoGK 2.40
[06.04.2007 17:38:42] OS: WinXP (5.1.2600).2
[06.04.2007 17:38:42] Job started.
[06.04.2007 17:38:42] Input file: D:\Milan-Bayern.mpg
[06.04.2007 17:38:42] Output file: D:\Milan-Bayern.avi
[06.04.2007 17:38:42] Output codec: XviD
[06.04.2007 17:38:42] Audio 1: Audio Stream 0 MPEG
[06.04.2007 17:38:42] Subtitles: none
[06.04.2007 17:38:42] Format: AVI
[06.04.2007 17:38:42] Target quality: 58%
[06.04.2007 17:38:42] Audio 1 settings: CBR MP3 with bitrate: 160Kbps
[06.04.2007 17:38:42] Started encoding.
[06.04.2007 17:38:42] Demuxing and indexing.
[06.04.2007 17:42:41] Processing file: D:\Milan-Bayern.mpg
[06.04.2007 17:42:41] Source resolution: 720x576
[06.04.2007 17:42:41] Found PAL source.
[06.04.2007 17:42:41] Source aspect ratio: 16:9
[06.04.2007 17:42:41] Color correction enabled.
[06.04.2007 17:42:41] Analyzing source.
[06.04.2007 17:48:14] Source has percentage of interlacing in motion areas: 93,75
[06.04.2007 17:48:14] Source is considered to be interlaced.
[06.04.2007 17:48:14] Output will contain 149162 frames
[06.04.2007 17:48:14] Encoding audio.
[06.04.2007 18:07:50] Running single pass encoding.
[06.04.2007 18:07:50] Writing the following script to D:\agk_tmp\Milan-Bayern_movie.avs
LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\ColorMatrix.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE3.dll")
LoadPlugin("C:\PROGRA~1\AutoGK\filters\leakkerneldeint.dll")movie = mpeg2source("D:\agk_tmp\Milan-Bayern.d2v")
cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=34,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0)
fixed_aspect = 1.42222222222222
c_width = width(cropclip)
c_height = round(height(cropclip) / fixed_aspect)
input_par = float(c_width)/float(c_height)
input_par = (input_par > 1.4) (input_par < 1.25) ? input_par : (4.0/3.0)
out_width = 720
out_height = round(float(out_width) / input_par)
hmod = out_height - (floor(out_height / 16 ) * 16)
out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
LeakKernelDeInt(movie,order=1,sharp=true)
autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=34,samplestartframe=0,leftadd=0,rightadd=0,topadd=0,bottomadd=0)
LanczosResize(out_width,out_height)
RemoveGrain(mode=2)
ColorMatrix("Rec.709->Rec.601",opt=0,hints=false)
[06.04.2007 21:19:28] Duration was: 3 hours 11 minutes 37 seconds
[06.04.2007 21:19:28] Speed was: 12,97 fps.
[06.04.2007 21:19:28] Job finished. Total time: 3 hours 40 minutes 45 seconds
