FFmpegSource - vielfältiges Source-Plugin für AviSynth basierend auf ffmpeg / lav
  • Wieder ein aktuelles Build:
    Zitat von qyot27
    FFMS2 C-plugin r1015+85
    Optimized for Pentium-III and SSE.
    ffmpeg version r71895 git-0eec40b Copyright (c) 2007-2015 the FFmpeg developers
    built with gcc 5.1.0 (GCC)
  • I am here to inform you of the glorious new 2.21 release. Go and update because it actually is a lot better than the previous one.
    Quellen: https://github.com/FFMS/ffms2/
    Release: https://github.com/FFMS/ffms2/releases
    Mostly maintenance bug fixes and a much newer FFmpeg version, but there's also new API stuff for indexing files to support files with more than 32 tracks. The non-FFmpeg Matroska, MPEG-TS and OGM parsers have been dropped since these days libavformat's are good enough (and sometimes better).
    • Add missing constants for log levels (Myrsloik)
    • Fix bad decoder flush that discards the palette of raw video (Myrsloik)
    • Remove the SWScale function from Avisynth since SWScale is useless (Myrsloik)
    • Fix common framerate correction (Myrsloik)
    • vapoursource: The framerate and frame durations are now normalized (Myrsloik)
    • vapoursource: Add support for outputting the alpha channel too (Myrsloik)
    • vapoursource: Fix resizer selection so bicubic isn't always used (Myrsloik)
    • vapoursource: Set chroma location and full colorspace information (Myrsloik)
    • Add support for indexing files with more than 32 tracks and the possibility to skip indexing of video tracks (Myrsloik)
    • The Avisynth plugin now sets all per frame variables in all modes to avoid ugly and slow FFInfo() errors (Myrsloik)
    • vapoursource: Fix crash on single frame files (Myrsloik)
    • Remove the Matroska and Haali demuxers (qyot27, Plorkyeran)
    • Fix adjustments for positive audio delay (tophf)
    • Don't try to index video tracks in unsupported formats (Daemon404)
    • Don't use scientific notation in timecode files (Daemon404)
    • Fix utf8 support in FFVideoSource (nixxquality)
    • Improve handling of files where only some packets have timestamps (Plorkyeran)
    • Fix memory leaks in the VapourSynth error handling (Plorkyeran)
    ICL version is typically ~10% faster on Intel CPUs, but is less tested.
    Auf gute Zusammenarbeit:
    Einmal editiert, zuletzt von LigH (17. Mai 2015 um 14:46)
  • Bugfix von qyot27: Bei aktivierter Baum-Vektorisierung compiliert GCC 5.3.0 leider ffmpeg fehlerhaft.
    Zitat von qyot27
    FFMS2 C-plugin r1110+98
    Optimized for Pentium III and SSE.
    ffmpeg version r79153 git-c2bbcf1 Copyright (c) 2000-2016 the FFmpeg developers
    built with gcc 5.3.0 (GCC)
    Actually up-to-date this time. The Access Violation issue from before was due to FFmpeg getting miscompiled (-fno-tree-vectorize fixes that problem).
  • FFMS2 v2.23 ist erhältlich, läuft aber angeblich so nicht mehr unter XP, auch wenn es bei real.finder doch laufen soll... :grübeln: – XP hab ich nicht mehr.
    Einen etwas umständlichen Lösungsversuch dafür mit vielen zusätzlichen DLLs gibt es von FranceBB im doom9-Forum. — Wird entfernt.
    Sinnvoller dürfte das FFMS2 C-plugin 1140+101 von qyot27 im doom9-Forum sein, das nicht einmal SSE2 erfordern soll.
    Einmal editiert, zuletzt von LigH (20. Oktober 2016 um 08:50)
