madVR - high quality video renderer (GPU assisted)
0.87.20 -> added x64 build ENDLICH!!!
ZitatmadVR v0.88.1
* added Direct3D 11 presentation path
* added support for native 10bit output
* added NEDI image doubling option
* added "image enhancements" settings page for source enhancements
* added "upscaling refinement" settings page for upscaling post processing
* added FineSharp to source enhancement and upscaling refinement
* added LumaSharpen to source enhancement and upscaling refinement
* added SuperRes to upscaling refinement
* added chroma upscaling option "activate SuperRes filter"
* added Shiandow's deband algorithm
* removed chroma image doubling options
* fixed some 64bit stability issues
* fixed crash when two madVR instances had the same parent (DVBViewer BiB)
* fixed one potential DXVA decoding freeze
* trade quality option "lose BTB and WTW..." is disabled by default now
* added SettingsSetBoolean("FinalizeOnWMClose") option
* (un)install.bat now complains if you don't run them as admin
* (un)install.bat now doesn't try to install madVR64 on a 32bit OS, anymore -
0.88.2
Code* added D3D11 option "present a frame for every VSync" * added option to choose medium/high SuperRes error upscaling quality * pages "image enhancements" and "upscaling refinement" are now profileable * fixed: dark video in windowed mode when using error dif with 10 bit display * fixed: FineSharp modes 2 and 3 corrupted image quality * fixed: some controls (FSE seekbar, and ZoomPlayer controls) didn't work * fixed: corrupted render times and more when using a lot of rendering steps * madVR no longer disables desktop composition when D3D11 is activated * if DWM is disabled, when madVR starts, D3D9 is used instead of D3D11 * if DWM is disabled while madVR renders with D3D11, madVR pauses playback
0.88.6
Code* fixed: D3D11 rendering sometimes got stuck (e.g. when minimizing player) * fixed: NNEDI3 quadrupling with SuperRes didn't work properly (NVidia only) * fixed: refresh rate fix didn't work in 64bit * added D3D11 refresh rate fix (proper support for 23p vs. 24p etc) * added option "octuple luma/chroma resolution" * re-added NNEDI3 chroma doubling options * removed limitation to double chroma with Catmull-Rom * updated Shiandow deband algorithm to latest version
0.88.9
Alles anzeigen* optimized lots of HLSL pixel shaders -> performance improvements * added a dedicated downscaling render path to speed up 4K playback etc * removed "bad" scaling algos (Lanczos8, Jinc4, Jinc8) * modified "high" deband preset to also use gradiant angle analyzation * updated to latest Shiandow deband script * error diffusion now also supports 10bit output * modified D3D11 refresh rate behaviour * optimized rendering time averaging logic * rewrote "install.bat" and "uninstall.bat" once more * SMPTE 170M and SMPTE 240M are now using the SMPTE C 3dlut * sRGB now uses the BT.709 3dlut * fixed: JRiver MC20 crashed when stopping FSE 10bit playback
0.88.11
Alles anzeigen* fixed: SuperChromaRes produced green screen when downscaling video a lot * fixed: at exactly 50% zoom, chroma was always repositioned using Bilinear * fixed: some D3D11 objects were not properly released * fixed: D3D11 FSE losing focus resulted in black screen * fixed: one more D3D11 shutdown crash * fixed: fixed one more OpenCL compilation problem * fixed: crash when downscaling a lot, with media player asking for cropping * fixed: SuperChromaRes produced artifacts with "use 10bit chroma/luma" buffer * removed Shiandow's debanding algorith * added workaround for one cause of queues not filling in D3D11 FSE mode * modified "high" debanding preset one last (?) time * SoftCubic skips anti-ring now (AR harmed SoftCubic more than it helped)
0.88.12
Alles anzeigen* added super-xbr image doubling algorithm * added super-xbr chroma upscaling algorithm * added NEDI chroma upscaling algorithm * added workaround for one more cause of queues not filling in D3D11 FSE mode * removed FineSharp "mode", "repair" and "linear light" options * removed SuperRes "error upscaling quality" option * fixed: screenshots didn't always work when using DXVA scaling * fixed: luma quadrupling could introduce greenish tint * fixed: settings dialog required BT.709 3dlut slot to be filled * fixed: auto 3dlut slot switching didn't always work correctly * fixed: double clicking madTPG with D3D11 enabled -> black screen * fixed: custom shader "clock" parameter was not set correctly * fixed: ConfigureDisplayModeChanger(allowResolutionChanges = false) bug
0.88.13
Code* added super-xbr "sharpness" parameter (50, 75, 100 = default, 125) * big speed for super-xbr chroma upscaling * small speedup for super-xbr image doubling * FineSharp no longer uses linear light (for now) * added IMadVRCommand interface, replaces IMadVRSeekbar/ExclusiveModeControl * added IMadVRCommand::SendCommand("restoreDisplayModeNow") command * fixed: small logic/quality bug in super-xbr chroma upscaling * fixed: settings dialog always showed NNEDI3 chroma doubling to be enabled
0.88.14
Alles anzeigen* updated to latest Shiandow SuperRes version * added Bilateral chroma upscaling algorithm * added AdaptiveSharpen to "image enhancements" and "upscaling refinement" * improved luma anti-ringing quality for super-xbr image doubling * super-xbr chroma upscaling now supports enabling/disabling anti-ringing * added super-xbr sharpness options of 25 and 150 * ca. 30% performance boost for super-xbr image doubling * ca. 15% performance boost for super-xbr chroma upscaling * ca. 30% performance boost for FineSharp * removed "thinning" parameter from FineSharp, now always set to 0 * added various new madTPG APIs
0.88.16
Code* modified SuperRes algorithm slightly (faster, less artifacts, less sharp) * added SuperRes "use alternative color space" option * replaced SuperRes "HQ downscaling" option with new "algo" multi option * removed SuperRes "softness" option (now always 0.00) * fixed: decoder sending BT.2020 decoding matrix wasn't properly detected
0.88.17
Code* madVR now renders in paused and stopped mode, too * added automatic OSD low latency logic * added SuperRes anti-ringing filter * fixed little SuperRes quality detoriation introduced in v0.88.16 * fixed: high GPU consumption in paused mode (PotPlayer, Kodi DSPlayer) * all (useful) IVideoWindow APIs now work even when no pins are connected
