ZitatAlles anzeigenSupports and ONLY supports subtitle scripts supported by Official VSFilter 2.39 & 2.40 builds, but in a more efficient way.
What Is Different
- Much faster than Official VSFilter 2.39 & 2.40
- Subpics are now drawn directly in YUV/RGB as needed to improve performance
- Official VSFilter always rendered subtitles in RGB and did a RGB -> YUV conversion when outputting YUV formats
- More efficient Blur code
- Alpha blending on dirty areas of the frame only
- Alpha-blending with sub-sampled/interlaced chroma where applicable
- Addition of numerous caches to speed up animated effects
- Proper implementation of animation detection to speed up static typesetting
- New script parser to speed up loading of very large subtitle scripts
- 75% reduction in CPU load overhead when idle
- Input/Output support for 10-bit P010 & 16-bit P016 4:2:0 YUV formats
- Requires: madVR video renderer and a video decoder which supports P010 or P016 output to use this optional feature
- Input/Output support for NV12 & NV21 4:2:0 YUV formats
- Important for users of ATI GPUs and EVR-CP
- Sub-pixel Positioning configuration option [None, 2x2, 4x4, 8x8, 8x8(bilinear)]
- Official VSFilter defaults to 8x8. New method 8x8(bilinear) offers 8x8 positioning using bilinear scaling instead of rasterization.
- BT.709/BT.601 matrix configuration option for subtitle rendering
- Option for automatic matrix selection based on video resolution
- Official VSFilter always does color rendering using BT.601, so this has been left as the default for compatibility
- HDMV(PGS) & DVB Subtitle support from VSFilter 2.40
- Removed pre-buffer subpics option (may be re-added in the future)
Quelle: http://code.google.com/p/xy-vsfilter/
Gibt leider keine 64bit Version, sieht sonst aber interessant aus.
