Version 3.2 ist raus!
Zitat von DimadSoftAlles anzeigen
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] one-click "bypass menu" action for menu buttons (hides menu and modifiys navigation to behave like specified button is selected automatically)[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] stop preview playback before disk operations (import/export disk and save/load projects)
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] log&history panes "dissapear" on second program start
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] delete/insert command does not set edited flag
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] "Enable all operations" does not enable them in VOBUs in some cases
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] reworked docking panes mechanizm
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] "Reset layout" reset panes layout in all (not just in active) views to default layout
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] problem merging DVDs recorded by Sony DVD camcorders (direct usage of vmg_title register)
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] more illustrative docking in "Studio 2005"-like mode
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] program hangs while editing if there is PGC with more than 256 cells
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] check all PGCs (not just listed in titles) for angles
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] do not allow more then: 255 cells in PGC, 99 programs in PGC, 999 chapters in Title, 99 TitleSets, 99 Titles when editing disk
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] wrong item is selected in VMG Titles pane after editing title
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] shortcuts for "Insert Block", "Insert program", "Delete Block", "Delete Program" and "Delete program with blocks(s)" actions in PGC Programs pane
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] option in Options/Format dialog to show/hide button set attributes info in Buttons pane
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] "Edit button set attributes..." item to popup menus in Preview and Buttons panes
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] add "Duplicate" action for PGC and LU items in DVD Tree pane (creates new PGC/LU that reuses same blocks as original)
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] ability to pause I/O operations
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] attempt to import from VIDEO_TS sub folder when import is cancelled
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] "All modes" tab in Buttons pane
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] Shift+Space(Dbl_Click) on button in Preview pane to edit button command for all groups (without SHIFT Button editing dialog is opened)
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] Shift+Space(Dbl_Click) on button in Buttons pane to edit button command for selected group (without SHIFT Button editing dialog is opened)
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] "Del" shortcut for PGC/PGCs/VTS/LU items in DvdTree pane (delete selected item)
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] select item near deleted in DvdTree pane instead of parent item
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] crash when right-clicking in DvdTree pane on VTS that has titles pointing to deleted PGCs
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] DvdTree pane looses focus after some editing actions
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] highlight invalid commands and commands not allowed in particular domain
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/fix.gif] adjust force select & force action (if needed) when renumbering/deleting menu buttons
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] show buttons segment attributes (start/end highlight time, force select/action info) in Buttons pane
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] edit buttons segment attributes
[Blockierte Grafik: http://www.dimadsoft.com/dvdremakepro/images/new.gif] allow "add copied" menu PGC to VTS and vise versa
Cu Rippraff
