MeGUI Encoding-Frontend: aktuelle Versionen
  • 0.2.1.7 07/30/2005
    Benjamin Franklin (1706-1790)
  • update:
    MeGUI Thread
  • 0.2.1.8a 08/06/2005
    changed: updated version number
    changed: x264 quantizer delta is now set to 4 by default (it's the x264.exe default, mencoder uses 2 as the default)
    bugfix: automated 2/3 pass x264 jobs without using turbo would result in incorrect commandlines for the me method and subpel refinement
    bugfix: all GUI classes can be edited in the VS.NET GUI editor again
  • 0.2.1.9 08/13/2005 - "long release"
    new: bitrate calculations use 64 bit variables for filesize. This in turn leads to the following bugfix:
    bitrate calculations will be accurate even when going above 2.5 CDs, negative and grossly inaccurate bitrates should no longer ocurr. I've tested this up to a target size of 9999MB, which is the maximum size you're allowed to enter, but we should be okay even in the TB area with 64 bits. The audio file size is still a 32 bit integer but that should cover about 2 GB and I think we should be okay with that.
    changed: jobs, profiles and the log should be saved even if auto-shutdown is activated
    changed: when a job is restarted, its end time and fps will be cleared
    changed: when setting a zone, the zone start/end is cleared in the preview
    changed: added a "all supported files" filter to the d2v creator
    changed: updated the readme file
    changed: catching more errors from x264.exe
    changed: output filename is no longer filled in if a first pass profile is currently active
    bugfix: jobs are no longer automatically removed even if the corresponding setting isn't activated
    bugfix: decimal/double options should lead to correct commandlines even on locales that use a comma as decimal separator rather than a dot.
    bugfix: sar settings are overwritten with each profile.. if a profile has no sar settings, the sar will be cleared.
    MeGUI Thread
  • 0.2.2.0 08/18/2005
    new: confirmation box when the abort button is pressed
    changed: job name and progress is shown in the title during encoding
    changed: codec configuration windows are resized in a way that works even with granny fonts
    bugfix: audio encoding without volume correction no longer causes an internal crash that prevents encoding until MeGUI is closed
    bugfix: commandline generation when a codec configuration window is opened no longer causes crashes under special conditions
    bugfix: the calculator works properly in the x264-only version.
    MeGUI
    MeGUI x264 Edition
  • Und gleich die nächste Version hinterher:
    0.2.2.1 08/20/2005
    new: the fps shown in the queue is now the average FPS rather than the last reported FPS from the encoder. In addition, the precision of the FPS indicator has been improved.
    changed: position of job & percentage complete in the title when encoding
    changed: percentage complete is shown with two digits after the comma separator
    changed: snow first pass commandline defaults to constant quantizer (q5) with no video output to prevent corrupt output as snow is apparently unable to handle the stats generated by a regular first pass
    changed: when suggest resolution is active, changing the DAR triggers the resolution suggestion mechanism
    bugfix: encoding now stops at postponed jobs even if the jobs are linked
  • Und wieder ein paar bugs weniger! :D
    MeGui Thread
    MeGui x264 Edition Thread
  • Neue Version
    0.2.2.3 08/28/2005
    new: when encoding is paused (or on the way to.. x264.exe takes a while until it really stops and usually encodes between 50 - 100 frames after hitting the pause button), a start icon will appear to signal you're in pause mode. Press it and you'll be back active and the icon is back to pause.
    new: the number of cpu cores is automatically detected and the appropriate number of threads is used for lavc and x264.
    changed: x264 fourcc defaults to x264
    changed: language tags in mp4box commandlines have been changed to accomodate mp4box 0.4.x. As a result, you now must use mp4box 0.4.x when assigning languages to tracks, or muxing will fail.
    bugfix: x264 fourcc wasn't saved
    bugfix: snow 2/3 pass commandlines include the pass number for the first pass, which is needed to get a stats file
    MeGui Thread
  • und wieder eine MeGUI Version :D
    0.2.2.3a 08/29/2005
    new: compilation script for the .NET SDK commandline compiler. You no longer require Visual Studio.NET to compile the application. However, anything that touches GUI components still needs to be done in Visual Studio - the GUI should always be editable in the VS.NET GUI editor. Compiling via csc seems to lead to smaller executables so this will be the default way binaries are distributed from this point on. If you encounter any problems with the new binaries, let me know.
    bugfix: re-imporated various GUI classes from an older release as they could no longer be opened by the VS.NET GUI designer for some wicked reason
    bugfix: mp4box muxing commandlines do not contain an immutable framerate when the muxing input is an mp4.
    MeGui Thread
  • Update !
    0.2.2.4 09/04/2005
    new: AR signalling for MKV and MP4 output in one click mode
    bugfix: x264 subq option was off by one in mencoder mode
    MeGui Thread
  • Zitat von Doom9
    0.2.2.5 09/20/2005
    new: intermediate files can be deleted automatically
    new: output of aborted jobs can be deleted automatically
    new: aac encoding using faac is now possible
    changed: stats file are written to the directory of the source and named to correspond to the source they are from
    changed: besweet logfiles are written to the destination directory and named to match the output
    bugfix: d2v files are no longer kept option
    MeGui Thread
  • update:
    0.2.2.5a 09/21/2005
    changed: dgindex demuxing now only demuxes the chosen audio tracks (unless you select demux all) - this may require an update of dgindex so check the requirements above
    changed: the way dgindex is being run has been simplified, this could potentially help people who've been having problems with the indexing function (I know of two people to have reported this). If it doesn't work, please download debugview from sysinternals, and run it while running megui and post the logged output here.
    MeGui Thread
    0.2.2.6 10/06/2005
    new: dgindex processing is now handled as a regular job. This allows queueing of multiple dgindex jobs, and thus the one click mode can process multiple movies after another, including the dgindex phase.
    changed: desired size in the autoencode window has been changed to MBs instead of KBs
    changed: .sub input has been replaced by .idx input for Subtitle muxing into mkv
    bugfix: aborting paused jobs and restarting them no longer causes a crash
    bugfix: moving jobs up/down works properly again
    MeGui Thread
  • update:
    0.2.2.8a 10/23/2005
    new: a series of connected jobs will be skipped if one job terminates with an error, allowing subsequent independent jobs to still be executed
    new: support for the x264 constant quality feature
    changed: x264 options that have to be disabled in the GUI are preserved (so e.g. you activate 8x8 dct and then go back to main profile, once you go back to high profile it will still be checked)
    changed: adapted AQ syntax to correspond to the latest patch
    0.2.2.9a 11/01/2005
    new: default settings for one click mode (thanks berrinam)
    new: you can now manually enter a negative audio delay (delay in filenames was always properly recognized
    changed: 0 delay is no longer added to the commandline
    changed: changed auto-force film to correspond to the latest dgindex file version.
    bugfix: fixed a tri-state problem in the x264 configuration (lossless mode)
    MeGui Thread
    0.2.3.0 11/04/2005
    new: you can opt to not have a progress window automatically open for each job
    new: support for x264's trellis
    bugfix: video profiles can once again be deleted
    bugfix: aborting a job when just one is in the queue no longer leads to a (non fatal) exception
    MeGui Thread
  • die Entwicklung geht zügig voran :)
    0.2.3.1 11/05/2005
    new: support for AVC levels (check this for details)
    new: support for B-frame RDO
    changed: all video and audio profile dropdowns are now sorted alphabetically
    bugfix: selecting 2pass first pass and then high profile, closing and reopening the x264 configuration screen no longer locks the encoding mode field.
    0.2.3.1 11/06/2005
    new: new compiler options to only expose x264 SVN options in the GUI rather than Sharktooth's patches as well. The releases you can download here will always support Sharktooth's patches but if you're using a vanilla SVN build of x264.exe (from http://x264.nl for instance), make sure you're using the SVN build and don't use any of Sharktooth's profiles that use non SVN options.
    bugfix: GUI resizes again in x264-only mode
    bugfix: besweet logfile paths include parantheses to allow filenames containing spaces
    bugfix: the nero aac commandline has a missing trailing bracket for the bsn options
    bugfix: certain of the nero aac gui options didn't have an effect on the commandline preview (keep in mind though that even now, the full commandline preview is only active if you've configured the input for audio encoding, because the input type decides whether you need the azid options in the commandline or not).
    MeGui Thread
