0.2.1.7 07/30/2005
ZitatAlles anzeigennew: you can re-open the status window if you've accidentally closed it
new: when using zones/credits/intro with xvid, filler zones with weight 1 are automatically inserted in between non adjacent zones, thus ensuring that all parts of the video that do not fall into any zone will be encoded with the proper bitrate
new: lavc #motion predictors flag is available
new: xvid custom quantizer matrices are fully supported (but mencoder will most likely not accept it due to the fact that paths contain a : on Windows)changed: video is now considered to start at frame 0 (preview, zones creation)
changed: lavc m4v is now longer dependant on VHQ/RDO being active
changed: weighted zones allow a wider range of modifiers (1% - 500% for lavc/snow, 1% to 5000% for x264)
changed: x264-only and snow-only mode are now fully working
changed: x264 jobs are also marked as erroneous if x264.exe exits with an exitcode other than 0bugfix: proper default values for lavc quantizer blur and quantizer compression
bugfix: x264 first pass is working properly again
bugfix: snow SAD no longer causes an incorrect commandline
bugfix: weight zones are properly written (negative values in lavc/snow, multiplication factor rather than percentage in x264)
bugfix: all Forms that contain different elements depending on which mode the application is compiled can now be properly edited in VS.NET
