MeGUI Encoding-Frontend: aktuelle Versionen
  • Im Moment ist wenig Zeit für die Weiterentwicklung...
    2496 [MainForm]             enabled Drag & Drop for folders
    2495 [x265]                 introduced fastdecode & zerolatency tunings
    2494 [x265]                 removed --timinginfo switch. frame rate information is handled automatically now.
    Die Korrektur der Berechnung der Verlangsamung/Beschleunigung zwischen PAL und NTSC kommt auch noch in Kürze, sobald die Eigenheiten der Division in AviSynth verstanden wurden.
  • 2500 – stable
    2500 [x265]                 added custom command line
         [x265]                 added support for 64bit x265
         [x265]                 removed --no-ssim and --no-psnr as they are disabled by default
    2499 [Audio Encoder]        fixed TimeStretch support (regression of 2487)
         [Audio Encoder]        enhanced logging
         [Audio Encoder]        added 5.1 downmix if necessary (provided by tebasuna51)
    2498 [L-SMASH Indexer]      use the stream_index argument instead of track if using LWLibav*Source. Part II
    2497 [L-SMASH Indexer]      use the stream_index argument instead of track if using LWLibav*Source
    Auf gute Zusammenarbeit:
    Einmal editiert, zuletzt von LigH (22. Juni 2014 um 22:50)
  • Nachdem die 2500 auch "stable" wurde:
    2502
    2502 [Update]               fixed freeze when adding new custom update servers. Bug #769
    2501 [Update]               removed update server megui.xvidvideo.ru for the stable branch as it cannot be synced anymore
         [Update]               increased update data refresh interval to 10 days for the stable server
  • 2505
    2505 [Audio Encoder] fixed wrong channel count mismatch warning for AVS files. Bug #767
    2504 [Adaptive Muxer] fixed first subtitle unintended set to default. Bug #774
    2503 [L-SMASH Indexer] the cache file was sometimes not deleted
  • 2512
    2512 [OneClick] better support for Blu-ray playlist where eac3to and mediainfo report different track information
    2511 [Chapter Creator] improved error handling
    2510 [VobSubber] improved error handling
    2509 [OneClick] fixed removing the wrong subtitle track when using the DEL key
  • 2525
  • 2557
  • 2570
  • 2573
    2573 [Update]               sort date columns by date instead of string. Bug #810
    2572 [HD Streams Extractor] + [MediaInfo] if the language cannot be detected/matched the default MeGUI language will be used
    2571 [HD Streams Extractor] fixed some extract options (regression of 2564)
  • Zathor musste da mal die Struktur von Paketen umschreiben, weil ein Fehler beim Updaten nicht richtig bemerkt wurde. Außerdem läuft der Updater jetzt mit der gleichen .NET-Version wie das Hauptprogramm, nicht mit einer veralteten.
    P.S.: Noch zwei...
    2581
    2581 [Update]               if a update cache file is obsolete it will be retained for 90 days
    2580 [Update]               changed backup to be disabled by default
    2579 [Update]               improved handling of packages which require a restart
                                merged several MeGUI dlls into one package
    2578 [Main]                 a second instance of the same executable is blocked
                                if file permissions are not available MeGUI will not start
    2577 [Update]               improved handling of 7z archives which include files which need a restart
    2576 [Update]               switched the updater to .NET 4.0
    2575 [HD Streams Extractor] + [MediaInfo] missing language information in a video track will be ignored
    2574 [Log]                  added .NET 4.6 detection support
    Einmal editiert, zuletzt von LigH (30. August 2015 um 22:33)
