Erstmal Hallo zusammen,
Ich habe ein Problem, sobald es im Vorgang an das Encoden des Video gehen soll , bricht das Programm ab, stürzt aber nicht ab. Die installation funktionierte auch Problemlos
Hier das Loggbuch:
[04.08.2005 14:05:09] AutoGK 1.96
[04.08.2005 14:05:09] OS: WinXP (5.1.2600).2
[04.08.2005 14:05:09] Job started.
[04.08.2005 14:05:09] Indexing input for preview.
[04.08.2005 14:05:23] Processing file: D:\***
[04.08.2005 14:05:23] Source aspect ratio: 4:3
[04.08.2005 14:05:23] Source resolution: 704x576
[04.08.2005 14:05:23] Found PAL source.
[04.08.2005 14:05:23] Output will contain 5971 frames
[04.08.2005 14:05:23] Job finished. Total time: 14 seconds
[04.08.2005 14:05:35] AutoGK 1.96
[04.08.2005 14:05:35] OS: WinXP (5.1.2600).2
[04.08.2005 14:05:35] Job started.
[04.08.2005 14:05:35] Input file: Das verstrahlte Paradies.mpeg
[04.08.2005 14:05:35] Output file: D:\***
[04.08.2005 14:05:35] Audio: Audio Stream 0
[04.08.2005 14:05:35] Subtitles: none
[04.08.2005 14:05:35] Codec: XviD
[04.08.2005 14:05:35] Target size: 700Mb
[04.08.2005 14:05:35] Custom audio settings: VBR MP3 with average bitrate: 96Kbps
[04.08.2005 14:05:35] Started encoding.
[04.08.2005 14:05:35] Demuxing and indexing.
[04.08.2005 14:07:39] Processing file: D:\***
[04.08.2005 14:07:39] Source aspect ratio: 4:3
[04.08.2005 14:07:39] Source resolution: 704x576
[04.08.2005 14:07:39] Found PAL source.
[04.08.2005 14:07:40] Analyzing source.
[04.08.2005 14:11:29] Source is considered to be progressive.
[04.08.2005 14:11:29] Output will contain 122686 frames
[04.08.2005 14:11:29] Encoding audio.
[04.08.2005 14:20:46] Audio size: 63,484,226 bytes (60.54 Mb)
[04.08.2005 14:20:46] Overhead: 4,907,392 bytes (4.68 Mb)
[04.08.2005 14:20:46] Video size: 665,611,582 bytes (634.78 Mb)
[04.08.2005 14:20:46] Running compressibility test.
[04.08.2005 14:20:52] Duration was: 5 seconds
[04.08.2005 14:20:52] Speed was: 1138.09 fps.
EXCEPTION: Open avi failed.
[04.08.2005 14:20:52] Job finished. Total time: 15 minutes 17 seconds
Es wäre sehr nett, wenn mir da jemand helfen könnte.
Gruss Overlord
