AutoGK 1.96 Video Encoding Problem
  • Erstmal Hallo zusammen,
    Ich habe ein Problem, sobald es im Vorgang an das Encoden des Video gehen soll , bricht das Programm ab, stürzt aber nicht ab. Die installation funktionierte auch Problemlos
    Hier das Loggbuch:
    [04.08.2005 14:05:09] AutoGK 1.96
    [04.08.2005 14:05:09] OS: WinXP (5.1.2600).2
    [04.08.2005 14:05:09] Job started.
    [04.08.2005 14:05:09] Indexing input for preview.
    [04.08.2005 14:05:23] Processing file: D:\***
    [04.08.2005 14:05:23] Source aspect ratio: 4:3
    [04.08.2005 14:05:23] Source resolution: 704x576
    [04.08.2005 14:05:23] Found PAL source.
    [04.08.2005 14:05:23] Output will contain 5971 frames
    [04.08.2005 14:05:23] Job finished. Total time: 14 seconds
    [04.08.2005 14:05:35] AutoGK 1.96
    [04.08.2005 14:05:35] OS: WinXP (5.1.2600).2
    [04.08.2005 14:05:35] Job started.
    [04.08.2005 14:05:35] Input file: Das verstrahlte Paradies.mpeg
    [04.08.2005 14:05:35] Output file: D:\***
    [04.08.2005 14:05:35] Audio: Audio Stream 0
    [04.08.2005 14:05:35] Subtitles: none
    [04.08.2005 14:05:35] Codec: XviD
    [04.08.2005 14:05:35] Target size: 700Mb
    [04.08.2005 14:05:35] Custom audio settings: VBR MP3 with average bitrate: 96Kbps
    [04.08.2005 14:05:35] Started encoding.
    [04.08.2005 14:05:35] Demuxing and indexing.
    [04.08.2005 14:07:39] Processing file: D:\***
    [04.08.2005 14:07:39] Source aspect ratio: 4:3
    [04.08.2005 14:07:39] Source resolution: 704x576
    [04.08.2005 14:07:39] Found PAL source.
    [04.08.2005 14:07:40] Analyzing source.
    [04.08.2005 14:11:29] Source is considered to be progressive.
    [04.08.2005 14:11:29] Output will contain 122686 frames
    [04.08.2005 14:11:29] Encoding audio.
    [04.08.2005 14:20:46] Audio size: 63,484,226 bytes (60.54 Mb)
    [04.08.2005 14:20:46] Overhead: 4,907,392 bytes (4.68 Mb)
    [04.08.2005 14:20:46] Video size: 665,611,582 bytes (634.78 Mb)
    [04.08.2005 14:20:46] Running compressibility test.
    [04.08.2005 14:20:52] Duration was: 5 seconds
    [04.08.2005 14:20:52] Speed was: 1138.09 fps.
    EXCEPTION: Open avi failed.
    [04.08.2005 14:20:52] Job finished. Total time: 15 minutes 17 seconds
    Es wäre sehr nett, wenn mir da jemand helfen könnte.
    Gruss Overlord
  • Wie es aussieht kann er die AVI-Datei nicht öffnen.
    Mittlerweile gibt es die Version 2.13 wo so manche Probleme mit den AVIs behoben wurden.
    Installier mal die neuere Version und probiers nochmal :D
    Ach ja :welcome:
  • Zitat von Eriman
    Nicht böse sein, aber ich hoffe du hast hier keinen Eselsmist, da "Das verstrahlte Paradies" sich schwer nach "die Insel" anhört, der gerade im Kino läuft.
    Nene, ist ne Doku die von mir aufgenommen ist, über Atomversuche Frankreichs.
    Wegen dem Problem:
    Ich hab mal die neue Beta Version installiert, bisher ist das Problem nicht aufgetaucht. Falls jetzt alles geht sage ich vielen Dank für die freundliche Unterstützung, falls es nicht geht meld ich mich im Thread nochmals.
    Gruss Overlord
  • O.T.
    Mal ne Frage zwischendurch funktioniert Projectx auch mit Mpeg2-Dateien die von der Tunerkarte für Analog-TV erzeugt werden also keine DVB-Streams, denn bei meiner anlogen TV-Karte mit Hardware Mpeg2-Encoder funktioniert Projectx nicht, sprich Ton u. Video werden nicht getrennt.
    Overlord ist deine Mpeg2-Datei ein Transport Stream?
    Gruß, billy
    Intelligente Menschen sind immer freundlich (Jean Paul Sartre)
  • Hab's nochmal getestet, Projektx funktioniert manchmal mit den normalen mpeg-Files, manchmal Absturz. Bei mpeg-Streams habe ich keine Probleme. Na ja wird vielleicht am Programm u. meiner Rechnerkonfiguration liegen, aber ich werde dieser Sache nicht weiter nachgehen.
    Gruß, billy
