Mpeg4modifier ist ein Tool, das es ermöglicht Userdaten eines MPEG4-ASP Files (XviD, DiVX) ohne Recodierung zu verändern. So kann z.B das AR-Flag neu gesetzt werden oder auch packed bitstream hinzugefügt bzw. entfernt werden.
Mpeg4modifier läuft nur unter NET Framework 2.0 (s. Download bei windows update)
Changelog
ZitatAlles anzeigenNOTE: Aspect ratio modification works by changing a flag in the VOL headers, which is ignored by most decoders.
1.4.2 (2006-Sep-16):
* Fixed several problems with OpenDML reading/writing (writing bad OpenDML index entries, out of memory exception or unnecessary reading when loading, incomplete loading of files with damaged/missing index).
1.4.1 (2006-Aug-04):
* Fixed some problems with packing which also required corrections to the timestamp calculation code.
* If you try to load a non-MPEG4 video, the error message now displays which codec the file uses.
* Better default directories for load/save file dialogs.1.4.0 (2006-Aug-03):
* AVI handling code completely rewritten, supports OpenDML and incomplete files (rebuilds the index including keyframe flags).
* Ability to add/readd packed bitstream.
* Optimized some parts, runs significantly faster.
* Added Cancel button on load/save progress window.
* Doesn't freeze explorer while loading a file after dropping onto the source textbox.
* Updated code to take advantage of C# 2.0 features, and lots of cleanup.
http://www.moitah.net/
Thread auf Doom9
--> Weiterhin gibt es eine Kommandozeilenvariante: Infos und Download auf Doom9
