Hallo zusammen,
ich exportiere aus Adobe Premiere Elements ein unkomprimiertes AVI, dieses möchte ich mit mencoder in Xvid oder x264 (AVI) encodieren, leider bekomme ich immer eine Fehlermeldung und das encoden bricht nach dem 22 Frame ab:
mencoder -ovc xvid -ofps 25 -oac mp3lame -srate 44100 -of avi -mc 0 -xvidencopts bitrate=1500 -lameopts "cbr:preset=128:mode=0" -o konverter_master_xvid.avi konverter.avi
MEncoder 1.0rc1-3.4.2 (C) 2000-2006 MPlayer Team
CPU: Genuine Intel(R) CPU T2500 @ 2.00GHz (Family: 6, Model: 14, Stepping: 8)
CPUflags: Type: 6 MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 0 SSE2: 0
Compiled with runtime CPU detection.
Warning streams need a type !!!!
success: format: 0 data: 0x0 - 0x0
AVI file format detected.
VIDEO: [] 768x576 32bpp 25.000 fps 185540.1 kbps (22648.9 kbyte/s)
[V] filefmt:3 fourcc:0x0 size:768x576 fps:25.00 ftime:=0.0400
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 44100 Hz, 2 ch, s16le, 1411.2 kbit/100.00% (ratio: 176400->176400)
Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
xvid: using library version 1.1.0 (build xvid-1.1.0)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video decoder: [raw] RAW Uncompressed Video
VDec: vo config request - 768 x 576 (preferred colorspace: BGRA)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
The selected video_out device is incompatible with this codec.
Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp.
VDecoder init failed :(
VDec: using BGRA as output csp (no 0)
Opening video filter: [flip]
Movie-Aspect is undefined - no prescaling applied.
SwScaler: reducing / aligning filtersize 1 -> 4
SwScaler: reducing / aligning filtersize 1 -> 1
SwScaler: reducing / aligning filtersize 9 -> 8
SwScaler: BICUBIC scaler, from rgb32 to yuv420p using MMX2
SwScaler: using 4-tap MMX scaler for horizontal luminance scaling
SwScaler: using 4-tap MMX scaler for horizontal chrominance scaling
SwScaler: using 1-tap MMX "scaler" for vertical scaling (YV12 like)
SwScaler: 768x576 -> 768x576
Opening video filter: [expand]
Expand: -1 x -1, -1 ; -1, osd: 0, aspect: 0.000000, round: 1
videocodec: XviD (768x576 fourcc=44495658 [XVID])
xvid: par=0/0 (vga11), displayed=768x576, sampled=768x576
xvid: CBR Rate Control -- bitrate=1500kbit/s
Selected video codec: [rawbgr32flip] vfm: raw (RAW BGR32)
preset=128
MP3 audio selected.
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
Writing header...
ODML: vprp aspect is 4:3.
Setting audio delay to 0.052s.
Writing header...
Pos: 0.5s 14f ( 1%) 7.24fps Trem: 2min 4mb A-V:0.000 [0:0]
Badly interleaved AVI file detected - switching to -ni mode...
Pos: 0.6s 20f ( 2%) 5.31fps Trem: 2min 2mb A-V:0.000 [0:127]
1 duplicate frame(s)!
Pos: 0.7s 21f ( 2%) 5.58fps Trem: 2min 2mb A-V:0.000 [0:127]
Pos: 0.7s 22f ( 2%) 5.84fps Trem: 2min 2mb A-V:0.000 [0:127]
Flushing video frames
CBR audio: 16000 bytes/sec, 418 bytes/block
Writing index...
Writing header...
Setting audio delay to 0.040s.
Video stream: 375.130 kbit/s (46891 B/s) size: 37513 bytes 0.800 secs 22 frames
Audio stream: 127.999 kbit/s (15999 B/s) size: 19644 bytes 1.228 secs
Alles anzeigen
Wie kommt es zu einem "Badly interleaved AVI?"
