Hallo ich versuche grade einen Clip ins .mp4 Format umzuwandeln allerdings gibt er mir die Datei immer in so einem eigenartigen Format aus. Nämlich .3ivx.mp4 Seht Selbst :
http://img523.imageshack.us/img523/419/screenax3.jpg
Das zeigt er mir beim Encoden an:
======Encoding AAC audio======
Freeware Advanced Audio Coder
FAAC 1.24.1 (May 17 2005) UNSTABLE
Average bitrate: 128 kbps
Quantization quality: 100
Bandwidth: 16000 Hz
Object type: Low Complexity(MPEG-4) + M/S
Container format: MPEG-4 File Format (MP4)
Encoding C:\Programme\makemp4\mav.wav to C:\Programme\makemp4\temp\mav.m4a
frame | bitrate | elapsed/estim | play/CPU | ETA
789/789 (100%)| 99.9 | 1.6/1.6 | 11.72x | 0.0
======= x264 pass 1/3 ========
avis [info]: 800x592 @ 25.00 fps (457 frames)
x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
x264 [info]: slice I:2 Avg QP:34.50 Avg size: 926
x264 [info]: slice P:271 Avg QP:42.71 Avg size: 825
x264 [info]: slice B:184 Avg QP:32.71 Avg size: 131
x264 [info]: slice I Avg I4x4:1.8% I8x8:12.0% I16x16:86.2%
x264 [info]: slice P Avg I4x4:0.3% I8x8:1.6% I16x16:6.9% P:4.7% P8x8:0.1%
PSKIP:86.4%
x264 [info]: slice B Avg I4x4:0.0% I8x8:0.1% I16x16:0.2% P:1.6% B:0.1% B8
x8:0.0% DIRECT:0.1% BSKIP:97.8%
x264 [info]: 8x8 transform intra:18.2% inter:44.9%
x264 [info]: kb/s:109.2
encoded 457 frames, 7.30 fps, 109.52 kb/s
======= x264 pass 2/3 ========
x264 [info]: slice I:2 Avg QP:36.00 Avg size: 4665
x264 [info]: slice P:271 Avg QP:41.22 Avg size: 750
x264 [info]: slice B:184 Avg QP:37.41 Avg size: 107
x264 [info]: slice I Avg I4x4:4.9% I8x8:14.9% I16x16:80.3%
x264 [info]: slice P Avg I4x4:0.3% I8x8:1.7% I16x16:8.6% P:7.3% P8x8:0.1%
PSKIP:82.0%
x264 [info]: slice B Avg I4x4:0.0% I8x8:0.1% I16x16:0.3% P:2.0% B:0.0% B8
x8:0.0% DIRECT:0.1% BSKIP:97.4%
x264 [info]: 8x8 transform intra:16.4% inter:58.8%
x264 [info]: kb/s:101.6
encoded 457 frames, 6.43 fps, 101.95 kb/s
======= x264 pass 3/3 ========
x264 [info]: slice I:2 Avg QP:38.00 Avg size: 3479
x264 [info]: slice P:271 Avg QP:41.21 Avg size: 750
x264 [info]: slice B:184 Avg QP:37.74 Avg size: 101
x264 [info]: slice I Avg I4x4:3.4% I8x8:70.5% I16x16:26.2%
x264 [info]: slice P Avg I4x4:0.3% I8x8:1.8% I16x16:8.9% P:7.2% P8x8:0.1%
PSKIP:81.7%
x264 [info]: slice B Avg I4x4:0.0% I8x8:0.1% I16x16:0.3% P:1.9% B:0.0% B8
x8:0.0% DIRECT:0.1% BSKIP:97.6%
x264 [info]: 8x8 transform intra:20.1% inter:61.6%
x264 [info]: kb/s:100.2
encoded 457 frames, 6.97 fps, 100.54 kb/s
=== Muxing Audio and Video ===
AVC-H264 import - frame size 800 x 592 at 25.000 FPS
Adjusting AVC SizeLength to 16 bits
Import results: 457 samples - Slices: 2 I 271 P 184 B - 1 SEI - 2 IDR
IsoMedia import - track ID 1 - Audio (SR 44100 - 2 channels)
Saving C:\Programme\makemp4\mav.mp4: 0.500 secs Interleaving
If you have any errors, you haven't edited makemp4.bat correctly!!!
Otherwise the video is now done and can be found with the filename:
mav.mp4
Drücken Sie eine beliebige Taste . . .
und das hier sind meine Einstellungen :
@echo off
: See http://wiki.meaz.org/index.php?title=Codecs:x264 for latest info
:START
: Start Configuration
: You need to export your movie as an avi with a filename.
: You need to export your movie sound as a wav with the same filename.
: Set the filename you will use on here.
set mymovie=mav
:set the path to your files here (no \ at the end)
set mypath=C:\Programme\makemp4
:set the audio bitrate to use here
set myabitrate=128
:set the video bitrate to use here
set myvbitrate=100
:set the video frame rate you used here
set myfps=25
:End Configuration
mkdir %mypath%\temp
cls
echo AVISource("%mypath%\%mymovie%.avi") > "%mypath%\%mymovie%.avs"
echo Crop(0,4,-0,-4) >> "%mypath%\%mymovie%.avs"
echo ConvertToYV12() >> "%mypath%\%mymovie%.avs"
echo ======Encoding AAC audio======
"bin\faac.exe" -b %myabitrate% -o "%mypath%\temp\%mymovie%.m4a" "%mypath%\%mymovie%.wav"
echo ==============================
echo.
echo ======= x264 pass 1/3 ========
"bin\x264.exe" -p 1 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output NUL "%mymovie%.avs"
echo.
echo ======= x264 pass 2/3 ========
"bin\x264.exe" -p 3 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output NUL "%mymovie%.avs"
echo.
echo ======= x264 pass 3/3 ========
"bin\x264.exe" -p 2 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output "temp\%mymovie%.264" "%mymovie%.avs"
echo.
echo === Muxing Audio and Video ===
"bin\mp4box" -new -add "%mypath%\temp\%mymovie%.264#video" -add "%mypath%\temp\%mymovie%.m4a#audio" -fps %myfps% "%mypath%\%mymovie%.mp4"
echo.
if EXIST "%mypath%\%mymovie%.mp4" rmdir /S /Q temp
del "%mypath%\%mymovie%.avs"
:END
echo If you have any errors, you haven't edited makemp4.bat correctly!!!
echo Otherwise the video is now done and can be found with the filename:
echo %mymovie%.mp4
echo.
pause
Was mach ich denn nu falsch? Oo
