Fehler im Dateiformat
  • Hallo ich versuche grade einen Clip ins .mp4 Format umzuwandeln allerdings gibt er mir die Datei immer in so einem eigenartigen Format aus. Nämlich .3ivx.mp4 Seht Selbst :
    http://img523.imageshack.us/img523/419/screenax3.jpg
    Das zeigt er mir beim Encoden an:
    ======Encoding AAC audio======
    Freeware Advanced Audio Coder
    FAAC 1.24.1 (May 17 2005) UNSTABLE
    Average bitrate: 128 kbps
    Quantization quality: 100
    Bandwidth: 16000 Hz
    Object type: Low Complexity(MPEG-4) + M/S
    Container format: MPEG-4 File Format (MP4)
    Encoding C:\Programme\makemp4\mav.wav to C:\Programme\makemp4\temp\mav.m4a
    frame | bitrate | elapsed/estim | play/CPU | ETA
    789/789 (100%)| 99.9 | 1.6/1.6 | 11.72x | 0.0
    ======= x264 pass 1/3 ========
    avis [info]: 800x592 @ 25.00 fps (457 frames)
    x264 [info]: using cpu capabilities MMX MMXEXT SSE SSE2
    x264 [info]: slice I:2 Avg QP:34.50 Avg size: 926
    x264 [info]: slice P:271 Avg QP:42.71 Avg size: 825
    x264 [info]: slice B:184 Avg QP:32.71 Avg size: 131
    x264 [info]: slice I Avg I4x4:1.8% I8x8:12.0% I16x16:86.2%
    x264 [info]: slice P Avg I4x4:0.3% I8x8:1.6% I16x16:6.9% P:4.7% P8x8:0.1%
    PSKIP:86.4%
    x264 [info]: slice B Avg I4x4:0.0% I8x8:0.1% I16x16:0.2% P:1.6% B:0.1% B8
    x8:0.0% DIRECT:0.1% BSKIP:97.8%
    x264 [info]: 8x8 transform intra:18.2% inter:44.9%
    x264 [info]: kb/s:109.2
    encoded 457 frames, 7.30 fps, 109.52 kb/s
    ======= x264 pass 2/3 ========
    x264 [info]: slice I:2 Avg QP:36.00 Avg size: 4665
    x264 [info]: slice P:271 Avg QP:41.22 Avg size: 750
    x264 [info]: slice B:184 Avg QP:37.41 Avg size: 107
    x264 [info]: slice I Avg I4x4:4.9% I8x8:14.9% I16x16:80.3%
    x264 [info]: slice P Avg I4x4:0.3% I8x8:1.7% I16x16:8.6% P:7.3% P8x8:0.1%
    PSKIP:82.0%
    x264 [info]: slice B Avg I4x4:0.0% I8x8:0.1% I16x16:0.3% P:2.0% B:0.0% B8
    x8:0.0% DIRECT:0.1% BSKIP:97.4%
    x264 [info]: 8x8 transform intra:16.4% inter:58.8%
    x264 [info]: kb/s:101.6
    encoded 457 frames, 6.43 fps, 101.95 kb/s
    ======= x264 pass 3/3 ========
    x264 [info]: slice I:2 Avg QP:38.00 Avg size: 3479
    x264 [info]: slice P:271 Avg QP:41.21 Avg size: 750
    x264 [info]: slice B:184 Avg QP:37.74 Avg size: 101
    x264 [info]: slice I Avg I4x4:3.4% I8x8:70.5% I16x16:26.2%
    x264 [info]: slice P Avg I4x4:0.3% I8x8:1.8% I16x16:8.9% P:7.2% P8x8:0.1%
    PSKIP:81.7%
    x264 [info]: slice B Avg I4x4:0.0% I8x8:0.1% I16x16:0.3% P:1.9% B:0.0% B8
    x8:0.0% DIRECT:0.1% BSKIP:97.6%
    x264 [info]: 8x8 transform intra:20.1% inter:61.6%
    x264 [info]: kb/s:100.2
    encoded 457 frames, 6.97 fps, 100.54 kb/s
    === Muxing Audio and Video ===
    AVC-H264 import - frame size 800 x 592 at 25.000 FPS
    Adjusting AVC SizeLength to 16 bits
    Import results: 457 samples - Slices: 2 I 271 P 184 B - 1 SEI - 2 IDR
    IsoMedia import - track ID 1 - Audio (SR 44100 - 2 channels)
    Saving C:\Programme\makemp4\mav.mp4: 0.500 secs Interleaving
    If you have any errors, you haven't edited makemp4.bat correctly!!!
    Otherwise the video is now done and can be found with the filename:
    mav.mp4
    Drücken Sie eine beliebige Taste . . .
    und das hier sind meine Einstellungen :
    @echo off
    : See http://wiki.meaz.org/index.php?title=Codecs:x264 for latest info
    :START
    : Start Configuration
    : You need to export your movie as an avi with a filename.
    : You need to export your movie sound as a wav with the same filename.
    : Set the filename you will use on here.
    set mymovie=mav
    :set the path to your files here (no \ at the end)
    set mypath=C:\Programme\makemp4
    :set the audio bitrate to use here
    set myabitrate=128
    :set the video bitrate to use here
    set myvbitrate=100
    :set the video frame rate you used here
    set myfps=25
    :End Configuration
    mkdir %mypath%\temp
    cls
    echo AVISource("%mypath%\%mymovie%.avi") > "%mypath%\%mymovie%.avs"
    echo Crop(0,4,-0,-4) >> "%mypath%\%mymovie%.avs"
    echo ConvertToYV12() >> "%mypath%\%mymovie%.avs"
    echo ======Encoding AAC audio======
    "bin\faac.exe" -b %myabitrate% -o "%mypath%\temp\%mymovie%.m4a" "%mypath%\%mymovie%.wav"
    echo ==============================
    echo.
    echo ======= x264 pass 1/3 ========
    "bin\x264.exe" -p 1 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output NUL "%mymovie%.avs"
    echo.
    echo ======= x264 pass 2/3 ========
    "bin\x264.exe" -p 3 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output NUL "%mymovie%.avs"
    echo.
    echo ======= x264 pass 3/3 ========
    "bin\x264.exe" -p 2 --bitrate %myvbitrate% --ref 3 --bframes 3 --subme 6 --weightb --analyse all --8x8dct --qpmin 4 --qpstep 6 --merange 24 --me umh --progress --no-psnr --stats "temp\x264.stats" --output "temp\%mymovie%.264" "%mymovie%.avs"
    echo.
    echo === Muxing Audio and Video ===
    "bin\mp4box" -new -add "%mypath%\temp\%mymovie%.264#video" -add "%mypath%\temp\%mymovie%.m4a#audio" -fps %myfps% "%mypath%\%mymovie%.mp4"
    echo.
    if EXIST "%mypath%\%mymovie%.mp4" rmdir /S /Q temp
    del "%mypath%\%mymovie%.avs"
    :END
    echo If you have any errors, you haven't edited makemp4.bat correctly!!!
    echo Otherwise the video is now done and can be found with the filename:
    echo %mymovie%.mp4
    echo.
    pause
    Was mach ich denn nu falsch? Oo
  • Du hast eine Datei "mav", bei der die echte Dateiendung vor dir geheimgehalten wird, weil du den Windows-Explorer noch nicht korrekt eingestellt hast. Die Dateityp-Angabe "3ivx.mp4" ist keine Dateiendung, sondern nur ein vollkommen unwichtiger Hinweis darauf, dass diese Datei irgendwie von 3ivx wiedergegeben wird. So, wie Dateien mit der Endung ".txt" eben als "Textdatei" angezeigt werden, und Dateien mit der Endung ".bat" als "Stapelverarbeitungsdatei für MS-DOS" bezeichnet werden.
    Schalte erst mal aus, dass "Erweiterungen bei bekannten Dateien ausgeblendet" werden (Windows Explorer: Extras - Ordneroptionen - Anzeige).
  • danke für die antwort
    das habe ich jetzt gemacht. Bloß wie bekomme ich jetzt dieses .3ivx da weg? Ist das ein falscher codec den ich mal installiert hab?
    falls du wissen wolltest welches Format meine beiden Resourcen haben ist das .Avi und .wav
  • Das "3ivx" steht da, weil du anscheinend wohl irgend wann mal ein 3ivx-Paket installiert hast, und sich dadurch ein Programm daraus mit der Dateiendung ".mp4" verknüpft hat. Im Grunde ist es relativ nichtssagend, das kann man getrost ignorieren. Das ist kein Hinweis auf den tatsächlich verwendeten Codec!
    Um das zu ändern, müsste man in der Registry den Klasseneintrag ".mp4" bearbeiten, aber das würde ich selbst mir kaum zutrauen: Manchmal muss man hier ganze Ketten von Abhängigkeiten verfolgen, um herauszufinden, welcher Eintrag da verantwortlich ist. Zum Beispiel könnten da Abhängigkeiten herauskommen wie:
    .mp4 => mp4file => {$##-##-###-##} => Nero Digital ... (nur ein theoretisches Beispiel!)
    Schau mal - an deiner "mav.avi" steht auch als Erklärung "Video Clip". Welches Programm hat das wohl verursacht? Was hättest du dort lieber stehen - vielleicht "AVI-Datei"? Es wäre sicher möglich, das zu erreichen... aber den Aufwand ist es nicht wert, da kann einfach zu viel schiefgehen.
  • ich versteh nich worauf du hinauswillst :(
    Hab ich also direkt was beim .Avi rendern falsch gemacht und es geht deswegen nicht oder gibt es keine Lösung?
  • Nein.
    Ich meine: Die Datei ist völlig in Ordnung, und du regst dich über ein völlig uninteressantes Detail auf, das mit dem tatsächlichen Inhalt gar nichts zu tun hat.
    Wenn die MP4-Datei eine korrekt erzeugte MP4-Datei ist, dann spielt es überhaupt keine Rolle, welches Programm mit dieser Dateiendung verknüpft ist. Hauptsache ist doch, dass die Videodaten in der Datei fehlerfrei sind.
    Ich weiß beispielsweise, welche Art von Musik ich erwarten muss, wenn ich eine CD von "Orange Blue" höre. Egal ob das Cover rot, grün oder schwarz gefärbt ist.
    Und genauso bin ich damit zufrieden, wenn eine MP4-Datei die Endung ".mp4" hat, und wenn MPEG4-Video drin steckt. Egal ob sich beim Doppelklick nun der Mediaplayer öffnet, oder der 3ivx-Player.
  • danke waiser mann :seher: :D
    ich hätte vorher versuchen sollen es einfach abzuspielen, auch wenn es kein richtiges symbol hat :D
    ... man man man du kannst aber auch in rätseln reden :D
  • Woher soll ich den Wissensstand des Gesprächspartners kennen... Der eine diskutiert über die Wirkungsweise eines Wanckel, der andere weiß noch nicht mal, dass ein Motor gemeint ist. ;)
