Ich habe eine VOB Datei bei der PVA Strumento Probleme beim demuxen hat.
Das resultat: Der Ton hängt, ist Asynchron und es sind mitten im Film graue Standbilder zu sehen.
Die ursprünglichen VOBs lassen sich jedoch ohne fehler abspielen.
Demuxt wurde das ganze mit den standard Einstellungen
Hier die log in etwas verkürzter Fassung:
ZitatAlles anzeigen
*** PVAStrumento 2.1.0.17
*** running at 12-23-2007 18:53
Pre-Scanning input. May take some time.
Stream info for
G:\VIDEO_TS\VTS_01_1.VOBFound 1 video stream.
Found 1 AC3 audio stream.VIDEO #1
Resolution 720 x 576 (full D1)
Aspect ratio is 4:3
Frame rate 25.00 fps
Nominal bitrate 9800000 bps
First PTS: 00:00:00.201AC3 AUDIO #1
Format: 2/0
Sampled at 48.0 kHz.
<<DEMUXING>>
Input: G:\VIDEO_TS\VTS_01_1.VOB
Options
.. fixing startup delay.
.. fixing stream synch.
.. keeping track of audio offset accumulation.
.. strict checking of audio framing.
.. falling back to relaxed semantics on TS
.. dropping GOPs longer than 980 KB
.. splitting on change of video format.
.. splitting on change of audio format.
.. splitting on number of audio tracks.
.. clearing CDF
.. creating new GOP timecodes.
Closing starting GOP.
Aiming for sync at 00:00:00.201
Streamstart seems to be in (reasonable) sync:
Video 1 starts at 00:00:00.201
AC3 1 starts at 00:00:00.201
New MPEG video : D:\Neuer Ordner (2)\1\VTS_01_1_00.mpv
New AC3 audio : D:\Neuer Ordner (2)\1\VTS_01_1_00.ac3
ALERT> PTS reset in video. Have to re-sync.
Re-syncing.
Aiming for sync at 00:00:16.201
Cutting video.
AC3 stream 1: PTS DISCONTINUITY
Aiming for sync at 00:00:00.362
Cutting audio.
AC3 stream 1 now starts at 00:00:00.354
Video stream 1 now starts at 00:00:00.362
Re-syncing.
Aiming for sync at 00:00:02.050
Cutting video.
Aiming for sync at 00:00:00.722
Cutting audio.
AC3 stream 1 now starts at 00:00:00.738
Video stream 1 now starts at 00:00:00.722..................
Re-syncing.
Aiming for sync at 00:00:31.698
Cutting video.
Aiming for sync at 00:00:29.802
Cutting audio.
AC3 stream 1 now starts at 00:00:29.810
Video stream 1 now starts at 00:00:29.802
Re-syncing.
Aiming for sync at 00:00:31.666
Cutting video.
Aiming for sync at 00:00:00.676
Cutting audio.
AC3 stream 1 now starts at 00:00:00.684
Video stream 1 now starts at 00:00:00.676
Adjusting audio to frames in last GOP at EOF
Last fileset:
1038119902 total bytes written
Video 1: 30483 frames, 00:20:19.320
AC3 1: 38150 frames, 00:20:20.800
Sync estimate at EOF:
AC3 Audio #1 : 143 ms before video
*** Problem sections in output:
At or near 00:00:15.840 : Video #1
At or near 00:05:00.320 : Video #1
Video statistics
GOP length (min/avg/max):
1 / 10 / 15 [frames]
8917 / 357708 / 615128 [Bytes]
GOP bitrate (min/avg/max):
190 / 6687 / 13320 [kbps](Autosaving log to D:\Neuer Ordner (2)\1\VTS_01_1.txt)
Wie demuxe ich meine VOBs nun fehlerfrei ?
PS: Hab ProjectX versucht. Es macht aber die selben fehler wie PVAStrumento
