Ich öffne hier mal ein Support beitrag für LameXP, weil ich dies nicht so gut in Fremdländsch erklären kann, aber trotzdem etwas dazu schreiben möchte.
LameXP Bugs.Katjarella#001
* siehe Registry Problem: http://forum.doom9.org/showthread.php?p=1155722#post1155722
LameXP Bugs.Katjarella#002
* bei defekten FLAGs wird "All files have been encoded successfully!" gemeldet.
>> Done: Converted 1 files in 15 seconds. 0 errors occured.
Richtige Meldung erwünscht:
ZitatFLAC_DEF.flac: testing, 90% completeFLAC_DEF.flac: *** Got error code 0:FLAC__STREAM_DECODER_ERROR_STATUS_LOST_SYNC
FLAC_DEF.flac: ERROR while decoding data
state = FLAC__STREAM_DECODER_READ_FRAME
LameXP Bugs.Katjarella#003
* Bitraten Management bei MP3s stimmt nicht.
Compression Method: Quality-based
Quality/Bitrate: 0 (Highest)
Restrict Bitrates: Min=64 ; Max=240
[EXECUTION] Started by "*\lamexp.2008-07-07.debug.exe" [1064] [EXECUTION] Commandline - [ '*\lame_mp3.exe' --nohist -q 0 -V 0 -b 64 -B 240 --resample 44.1 -m s '*\lamexp_37ff4e26.wav' '*_sourcen\flac_ok.mp3' ]
Encoding as 44.1 kHz stereo MPEG-1 Layer III VBR(q=0) Frame | CPU time/estim | REAL time/estim | play/CPU | ETA 8206/8206 (100%)| 0:11/ 0:11| 0:11/ 0:11| 18.051x| 0:00[COLOR='Red'] 32 [ 129] %%[/COLOR] 64 [ 3] % 80 [ 0] 96 [ 1] %112 [ 2] %128 [ 3] %160 [ 23] %192 [ 385] %%%%224 [7660] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
Richtig mit Parameter : -F strictly enforce the -b option, for use with players that do not support low bitrate mp3
Encoding as 44.1 kHz stereo MPEG-1 Layer III VBR(q=0) Frame | CPU time/estim | REAL time/estim | play/CPU | ETA 8206/8206 (100%)| 0:11/ 0:11| 0:11/ 0:11| 18.051x| 0:00 64 [ 132] %% 80 [ 0] 96 [ 1] %112 [ 2] %128 [ 3] %160 [ 23] %192 [ 385] %%%%224 [7660] %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
Das gleich gilt für die Compression Method: Average Bitrate
LameXP Bugs.Katjarella#004
* GUI Fehler bei Average Bitrate + Restrict Bitrates
Es ist Möglich, eine höhere Average Bitrate anzugeben, als die Max Bitrate.
[EXECUTION] Commandline - [ '*\lame_mp3.exe' --nohist -q 0 [B][COLOR='Red']--abr 320[/COLOR][/B] -b 64 [B][COLOR='#ff0000']-B 224[/COLOR][/B] --resample 44.1 -m s "*\lamexp_eee17e58.wav" "*\flac_ok (6).mp3" ]
Globale Wünsche:
- keine Registry Einträge, erst recht keine Dateitypen Verknüpfung mit "LameXP.SupportedAudioFile". Und wenn dann nur per Nachfrage ( wie in der lamexp.2008-07-07.debug ) und NUR wenn es eine DeInstall funktion dazu gibt.
- extra Parameter wie zb: bei MP3 --vbr-new -p --strictly-enforce-ISO etc per INI Definition
Das wars erstmal und schaun, was denn der Hr. LoRd_MuldeR schreibt.
