Keine Ahnung, wenn Du rausbekommst wie die entsprechenden Parameter sind kann ich es unterstützen,...
MP3 CBR Stereo: -lameopts cbr:br=160:mode=0:aq=0
http://www.mplayerhq.hu/DOCS/man/de/mplayer.1.txt
siehe -lameopts
-lameopts help
vbr=<0-4> variable bitrate method
0: cbr (constant bitrate)
1: mt (Mark Taylor VBR algorithm)
2: rh (Robert Hegemann VBR algorithm - default)
3: abr (average bitrate)
4: mtrh (Mark Taylor Robert Hegemann VBR algorithm)
abr average bitrate
cbr constant bitrate
Also forces CBR mode encoding on subsequent ABR presets modes.
br=<0-1024> specify bitrate in kBit (CBR and ABR only)
q=<0-9> quality (0-highest, 9-lowest) (only for VBR)
aq=<0-9> algorithmic quality (0-best/slowest, 9-worst/fastest)
ratio=<1-100> compression ratio
vol=<0-10> set audio input gain
mode=<0-3> (default: auto)
0: stereo
1: joint-stereo
2: dualchannel
3: mono
padding=<0-2>
0: no
1: all
2: adjust
fast Switch on faster encoding on subsequent VBR presets modes,
slightly lower quality and higher bitrates.
preset=<value> Provide the highest possible quality settings.
medium: VBR encoding, good quality
(150-180 kbps bitrate range)
standard: VBR encoding, high quality
(170-210 kbps bitrate range)
extreme: VBR encoding, very high quality
(200-240 kbps bitrate range)
insane: CBR encoding, highest preset quality
(320 kbps bitrate)
<8-320>: ABR encoding at average given kbps bitrate.
Alles anzeigen
:lol: br=<0-1024> beides gleich mal testen naja doch nur 320k
