  • 2024.03.03.1:
    *fixed*
    • Avisynth: (32bit) SplineResize100/144 calls
    • Vapoursynth: custom section hinting accidentally required '# # ...' instead of '# ...'
    • Vapoursynth: allow lowering frame rate with rife
    • Vapoursynth: detect '2020 non .. ' as '2020cl'
    • Vapoursynth: crop in compare view
    • NoXSynth: fix subtitle embedding by changing local.conf handling
    • ui: subtitle controls enabled, even when no subititles are available
    *added*
    • Subtitle: Support embedding subtitle when QSVEncC/NVEncC with 'only use encoder' is used.
    • Torch: added DeOldify through vs-deoldify
    *changed*
    • Muxing/Extraction: Force FFmpeg for dts/dts-hd audio when dealing with mp4 containers.
    • Subtitle: Subtitle language passthrough handling.
    • Input: Support Gray8 input images.
  • 2024.03.10.1:
    *fixed*
    • FFmpeg: fixed color transfer signaling
    • Vapoursynth: GMFSS_fortuna model model index
    • Jobs: minimize command line glitch
    • Analysis: YUV jpeg handling
    *added*
    • Vapoursynth: add custom CropView pad color
    *changed*
  • 2024.03.18.1:
    *fixed*
    • UI: 'alwaysOnTop' caused Window to disappear
    • Vapoursynth: TFMBob fps calculation
    • Vapoursynth: CodeFormer in CompareView with 'undo upscale' disabled.
    *changed*
    • Vapoursynth: updated RIFE models
    • Vapoursynth/Torch: update vs-deoldify
  • 2024.04.06.1:
    *fixed*
    • Vapoursynth: VIVTC 'fix combed with deinterlacer'
    • Analysis: sox volume analysis
    • Audio: delaycut problems
    • Muxing: Crash with video pass-through
    • x264: disable 'adjust letterbox to crop' when Blu-ray/AVCHD restriction is enabled
    *changed*
    • Vapoursynth: BasicVSR++ added 'wanted width'
    • Vapoursynth: adjusted to vsDeOldify v3.0.1
    • Video: x265 adjusted to v3.6
    Ps.: also updated torch-addon
    ich habe Hybrid (den 105MB großen Download) unter Ubuntu 24.04 installiert. Es kommt die Meldung
    /home/nelson/.hybrid/fonts/local.conf does not exist!
    Im Grunde gibt es den gesamten Ordner 'fonts' nicht. DasProblem trat bei Ubuntu 22.04 nicht auf, da hatte ich aber seit Mitte 2023 kein Update mehr gemacht. Ich habe es mit einem frischen Ordner $USER/.hybrid versucht als auch mit einem Backup des alten vom 22.04 - immer das gleiche.
    Hybrid startet dann normal. Ein Encoding habe ich aber keines gemacht.
    _________________________
    Zieht ein Bienenschwarm aus, so wird er herrenlos, wenn nicht der Eigentümer ihn unverzüglich verfolgt oder wenn der Eigentümer die Verfolgung aufgibt.
    § 961 BGB [Eigentumsverlust bei Bienenschwärmen]
    :D
  • Ja, hat funktioniert.
    :D
  • Das mit dem WE wird wohl nix, da vsViewer nen fetten Memory leak hat werde ich wohl erst mal schauen ob ich das irgendwie behoben bekommen, sonst werde ich wohl vsViewer komplett austauschen. Dann gibt es erstmal ne Weile keine Hybrid updates,..
    (war nicht vsViewer sondern bifrost)
  • 2024.05.05.1:
    *changed*
    • Subtitle: handling IETF BCP 47 languages
    • torch-addon: adjusted to vsDeOldify
    • addon: updated and mlrt
    • Vapoursynth: experimental script highlighting option
    • Vapoursynth: removed vsQTGMC order; always set to -1
    • Vapoursynth: SoftLight 10bit support
    • mlrt-addon: using 'engine_folder' to make sure .engine files are created in temp folder
    *fixed*
    • Avisynth: TemporalDegrain2 postFFT handling
    • Vapoursynth: RGBH handling for CartoonEdges&Bloated-Edgemask
    • Crop: crop with multi-input
    • Muxing: mkv color signatling
    • Vapoursynth: use old RIFE version for FillDrops, FillDuplicates, ReplaceSingle due to: https://github.com/styler00dollar…FE-ncnn-Vulkan/ issues/16
    • Vapoursynth: Merge not working with FilterQueue
    • Vapoursynth: TemporalDegrain2 extraSharp=True crash
    *added*
    • mlrt-addon: SCUNet (mlrt)
    • Jobs: Vapoursynth chunking call
    • Avisynth: fixed TemporaDegrain(2) script/call
    • Vapoursynth: option for diff to increase difference visibility
    • torch-addon: VSGAN (filter only)
    *removed*
    • torch-addon: VSGAN parameters
  • Addons im Google Drive ... aha, mal schauen ... =O Wieviel?!?
    External Content www.youtube.com
    Content embedded from external sources will not be displayed without your consent.
    Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.
    ich habe hier offenbar eine etwas spezielle MKV-Datei, bei der sich aus Hybrid heraus keine MediaInfo Log-Datei schreiben läßt. Zumindest beschwert sich Hybrid mehrfach, daß es die Log-Datei nicht findet. Mit allen anderen Videos funktioniert es. Scheint also wirklich nur an diesem hier zu liegen. Version ist die aktuelle (mit älteren kommt aber der gleiche Fehler). System ist Debian Testing (Trixie) 64bit.
    Debug-Output: https://paste.quest/?167674124109e…skWfgPJPdReErAX
  • Die Datei ist zu groß, um sie übers Netz zu verschicken (30GB). Im Debug-Output kann man sehen, daß MediaInfo mehrmals aufgerufen wird und die ersten paar Male scheint es noch gut zu gehen. Aber am Ende enthält die Kommandozeile auffallend viele Sonderzeichen ( % und # ). Ich denke mal, da liegt der Hase im Pfeffer. Bedeutet, er kann Video- und Audio-Streams analysieren, nur bei den Untertiteln macht er Probleme.
    Ist also erst mal harmlos. Das Video an sich läßt sich öffnen, die Untertitel sind für mich nur sekundär.
  • In der aktuellen Version beschwert sich Hybrid auf einmal, daß es MKVToolnix Version 6.8.0+ braucht, um h.265 in MKV zu multiplexen. Das wäre eine Version von 2014. Ich nutze die aktuelle v84.0 über's Repo. System ist Debian Testing (Trixie) 64bit.
  • Die erkannten Versionen kannst Du auch bei "Config->Tools->Tool Versions" nachschauen.
    Wie sieht bei Dir die Ausgabe von "mkvextract --version" aus?
    Unter Windows habe ich z.B.
    mkvextract v85.0 ('Shame For You') 64-bit
    Hybrid verwendet dann:
    line = line.remove(0, line.indexOf(QString(" v")) + 2);
       line = line.remove(line.indexOf(BRACE1), line.size());
    und erhält "85.0"
    (könnte ich auch mal ne RegExp für schreiben,... jetzt wo ich den Code sehe,...)
  • "mkvextract --version" ergibt bei mir das:
    mkvextract v84.0 ('Sleeper') 64-bit
    Edit: Hat sich erledigt. Die gecachten Tool-Infos waren veraltet und wiesen noch auf die hauseigenen Tools, die mit dem Hybrid-Paket kommen und die unter Testing/Trixie teilweise nicht mehr laufen. Wußte auch nicht, daß man den Tools-Cache von Hand leeren muß, um aktuelle Infos zu laden.
    Edited once, last by pintcat (June 4, 2024 at 9:27 PM).
