r4194
ZitatAlles anzeigenRevision 4194 - Directory Listing
Modified Fri Dec 23 22:08:24 2011 UTC (2 hours, 13 minutes ago) by clsid2Cleaned up encoding code
Revision 4193 - Directory Listing
Modified Fri Dec 23 18:49:20 2011 UTC (5 hours, 32 minutes ago) by clsid2Updated Libav
Revision 4192 - Directory Listing
Modified Thu Dec 22 15:01:20 2011 UTC (33 hours, 20 minutes ago) by clsid2Updated Libav
Revision 4191 - Directory Listing
Modified Wed Dec 21 17:08:33 2011 UTC (2 days, 7 hours ago) by clsid2Updated Libav
Revision 4190 - Directory Listing
Modified Wed Dec 21 14:22:21 2011 UTC (2 days, 9 hours ago) by h_yamagatarevert rev 4014
Revision 4189 - Directory Listing
Modified Wed Dec 21 14:21:00 2011 UTC (2 days, 10 hours ago) by h_yamagatafix PGS subtitles crash
Revision 4188 - Directory Listing
Modified Tue Dec 20 23:31:50 2011 UTC (3 days ago) by XhmikosRupdate ICL12 projects for ICL 12 SP1 (update 6+)
Revision 4187 - Directory Listing
Modified Tue Dec 20 22:21:31 2011 UTC (3 days, 2 hours ago) by clsid2Cleanup belonging to previous commit
Revision 4186 - Directory Listing
Modified Tue Dec 20 22:09:16 2011 UTC (3 days, 2 hours ago) by clsid2Switch to w32pthreads
Revision 4185 - Directory Listing
Modified Tue Dec 20 20:20:33 2011 UTC (3 days, 4 hours ago) by clsid2Fixed crash with H.264 4:4:4 RGB
Now connection is rejected.
Revision 4184 - Directory Listing
Modified Tue Dec 20 20:10:22 2011 UTC (3 days, 4 hours ago) by egurUpdated to Intel QuickSynbc Decoder rev7.
Revision 4183 - Directory Listing
Modified Tue Dec 20 15:25:28 2011 UTC (3 days, 8 hours ago) by egurUpdated: Intel QuickSync Decoder to rev 6. Removed ICL 12.1 compilation errors and warnings.
Fixed ICL 12.1 compilation error in ffdshowDecVideoAllocatorDXVA.cpp.
No functionality change in either fix.Revision 4182 - Directory Listing
Modified Tue Dec 20 12:28:03 2011 UTC (3 days, 11 hours ago) by h_yamagataSorry, I shouldn't have committed TffdshowDecVideo.cpp at rev 4180. The change was meant to fix non-sense offset in AM_SAMPLE2_PROPERTIES. This commit disables extra debugging code.
Revision 4181 - Directory Listing
Modified Tue Dec 20 12:16:18 2011 UTC (3 days, 12 hours ago) by h_yamagatafixed race condition: ffdshow crashed depending on race condition at the start of MPEG-2 playback using libmpeg2 (this was hidden in release builds).
Revision 4180 - Directory Listing
Modified Tue Dec 20 12:13:05 2011 UTC (3 days, 12 hours ago) by h_yamagatafixed: TffdshowVideoInputPin::EndOfStream was not working for DirectShow encoder.
Revision 4179 - Directory Listing
Modified Tue Dec 20 12:07:00 2011 UTC (3 days, 12 hours ago) by h_yamagataCheck return value of IMediaSample::GetTime (libavcodec MPEG-2 (apparent only in debug builds): Fixed freeze issue on start of playback of m2v file with LAV Splitter.)
Revision 4178 - Directory Listing
Modified Tue Dec 20 12:00:26 2011 UTC (3 days, 12 hours ago) by h_yamagatafixed delay of soft telecine detection
Revision 4177 - Directory Listing
Modified Tue Dec 20 02:45:37 2011 UTC (3 days, 21 hours ago) by clsid2Some dxva changes from MPC-HC
Revision 4176 - Directory Listing
Modified Mon Dec 19 22:56:51 2011 UTC (4 days, 1 hour ago) by clsid2Updated Libav
Revision 4175 - Directory Listing
Modified Mon Dec 19 22:54:24 2011 UTC (4 days, 1 hour ago) by h_yamagatafix bad copy and paste in unused function
