Da ich noch keinen Eintrag dazu gefunden habe, poste ich das mal hier herein.
Die NLE Software Lightworks ist seit dem 30.11.10 Open Source.
Viel Vergnügen damit.
Falcon.
Falcon.
Alle mit Fragen bitte bei: http://forum.gleitz.info/showthread.php…)-zu-Lightworks posten und nicht im Newsbeitrag.
10.0.04 Beta
QuoteDisplay More* Fix crash when resizing video-routing panel
* Fix Exported DVCPro100 Quicktime playing correctly in FCP (Hardware I/O only)
* Fix crash trimming a single clip in a timeline
* Fix tools not returning correctly if toolbox is unpinned
* Fix audio only EDL Export
* Fix crash during OMF export with invalid shot
* Fix audio not being heard on audio tracks 17 and above (Hardware I/O only)
* Modify Mackie protocol to support edits with more than 16 audio tracks
* Fix SDI output not appearing when first entering a project (Hardware I/O only)
* Audio nodes can now be added by right clicking on the yellow line
* Fix output setting being reset when returning to the Project Browser
* Fix crash in notes section of Bin in Both view
* Fix WAV export failure
* Fix OMF WAV generation failure
* Fix sync errors incorrectly appearing when no V track is present
* Fix flashing black frames during DNXHD playback
* Fix tile distortion when dropping a tile into a gallery
* Fix colour not being displayed on colour correction wheels
* Fix odd behaviour clicking the Matrox screwdriver icon
* Fix 'make bin of clip-references' function
* Fix keyboard shortcuts getting lost randomly
* Fix OMF export panel distortion
* Restore audio level check box on OMF export panel
* Fix project browser when clicking in name section then changing to restore not letting you create a new project
* Added support for IMX decode (full version only)
* Fix EDL track mapping to support more than 4 audio tracks
* Fix two lists being created when searching for bins
* Add ability to turn off drag and drop behaviour (add config entry: stripv_accept_tiles 0 to the config.dat file)
* Fix automatic positioning option on bins
* Fix Solo button on audio mixer panel when audio is panned left/right
* Fix audio fade out line remaining on timeline when audio is removed
* Fix viewers distorting when changing size during playback
* Fix pinned viewers appearing on top when right-left clicking
* Fix EDL creation to correctly handle illegal characters in the filename
* Fix panel still on old colour scheme (add audio tracks in between)
* Fix 'right + left clicking' bringing bins to the top on the first click
* Fix horizontal scrolling on bins in List view
* Fix rendering of first effect in timeline removing additional effects
* Fix audio WAV export issue repeating the last section at the end of edit
* Fix crash when inserting from a sync-group using "Live cut source" shortcut
* Fix panels disappearing if toolbox is unpinned
* Fix tools staying in position when toolbox is unpinned
* Added keyboard shortcut for Next room and Previous room
* Fix crash clicking cutlist tool after sharking searchcard
* Fix black at end of edit being removed after clicking sync button
* Change user-generated black to a subclip
* Added keyboard shortcuts for next and previous audio node
* Stop network project notifications from being sent or received when not using shared projects
* Fix project output setting being saved per room (Shared projects only)
* Fix recording from MXO2
* Added ability to open file location from the Filecard
* Fix setting of aspect ratio when writing 16:9 using Gee file writer (MXF/MOV)
* Fix hang exporting OMF
* Fix audio playback stopping after a short time
* Fix consolidation to recognise all audio tracks correctly
* Tighten check for valid sequence numbers on OMF Export so we don't create unreadable OMFs
* Fix setting of filename when create new sound files on OMF import
* Fix infinite loop in OMF toolkit with invalid film frame sequence numbers
* Fix crash previewing audio only file on import panel
* Fix crash reading AVI audio using Gee file reader
* Fix reading of bits per component from Matrox YUV uncompressed files.
* Fix crash on exit
* Fix memory leaks and crashes on exit, generally when file requests fail for some reason.
* Fix shot length calculation (1 frame out)
* Improve audio file I/O efficiency
* Fix hang on shutdown of DirectShow audio interrupt when changing project standards
* Fix rounding of sample rate on OMF import
* Fix hang leaving room
* Keep logger window open for OMF imports (as well as AAF)
* Fix timecode from imported OMF not being displayed in 23.98 project
* Fix shot length calculation (1 frame out) on OMF import
* Fix problems with OMFs sometimes having no shot timecode, no reel etc.
* Fix crash during consolidate
* Fix video consolidation, log errors to error.log as well as console window
* Fix consolidate when there is insufficient audio or video samples in the original material, consolidate will continue without errors and the new material will resemble the original material in being longer than the actual material
* Fix crash on exit due to image cache not being empty.
* Add option to disable loading of Matrox codes for Vfw and DirectShow
* Fix crash importing Quicktime sample from forum (southpawami), Expand frame rates accepted as 30fps up to 31fps.
* Fix reading of MJPG_B movs, add reading of field presentation order, fix memory leak.
* Fix Consolidate not working correctly on BWAVs
* Fix several issues causing slow rendering.
* Fix crash previewing YUV images that need flipping on import
* Log Vfw codecs present to error.log
* Fix interleaving when creating new frames from 2 different input frames (pulldown) when the source image scan mode is not as expected (e.g. PAL material in an NTSC project).
* Added the ability to make multiple subclips at once from a clip with two or more cues
* Allow non-integral varispeeds
* Redraw existing tiles correctly following a change to project letterboxing
* Clicking the project location (on the project card) now causes the project folder to be revealed in Windows Explorer
* Fix crash applying effects via the routing panel (to non-visible parts of the graph)
* Fix crash starting playback (if you'd previously left a project having been in twin-play mode)
* Console trimming keys and keyboard trimming keys now do the same thing
* Added media relinking facility (bin->cogs-> Relink Missing Media)
* Fix crash after turning a clip into an edit (which is linked to a tile in a gallery)
* Fix crash trimming edit that has no video tracks
* Fix clipboard update bug
* Fix crash clicking on bin Notes fields
* Prevent graphical corruption on the consolidate panel
* Persist the advanced EDL export options (and restore for subsequent usages)
* Right mouse button now only moves the zoom window if zoomed in AND the mouse is over the white area
* Keep menus topmost
* Fix bin scrolling after drag/drop receipt of timeline section
* Claim focus when clicking 'all' button on timeline
* Fix insertion of single-frame clips when empty
* Rewrote the window manager
* Fix crash dragging and dropping a tile into a bin with no free space
* Added Vs_redist to the Full installer
* Fix error during install with vs-redist on Windows 7
* Fix Playout tool not resizing correctly when playout starts
* Fix EDL export ignoring audio tracks set to None
* Fix defaults button on logging databases
* Fix images not updating when trimming
* Fix Crash adding FX from simple effects panel when no V track selected
* Fix audio being moved correctly using disk manager tool
* Fix import panel disappearing if toolbox is unpinned
* Fix search and replace working on selections in Bins and logging databases
* Fix crash playing back 16bit DPX files
* Added support for up to 32 audio tracks
* Fix audio playback on NTSC AVI exports
* Fix v track being lost when unwiring FX
* Fix export panel remembering last image sequence setting
* Fix audio not getting moved when using disk manager tool
* Fix tile distortion when moving a tile that is partially covered in a bin
* Fix crash scrolling through bin in Both view
* Added ability to make subclips based on cue points
* Fix crash entering project if Fullscreen feature was enabled
* Fix decimal values being recognised on varispeed
* Fix certain keyboard shorctuts still appearing when they have been removed
* Fix search and replace can now replace text with empty field
* Fix yellow audio line being left behind when moving audio
* Fix crash importing AVI that has audio streams before the video streams
* Fix crash adding wipe effect in video routing panel
* Fix image sequence export creating a black frame at the end
* Fix tiles reparenting to what they were dropped on
* Fix crash after adding user defined effect
* Add support for Type 1 AVI files
* Fix MJPEG imports showing correct
* Fix crash exporting an EDL when there are less audio tracks in the edit than go in the EDL
* Fix crash scrolling bin contents (in list/both view)
* Reinstated memory reclaiming, now automatically frees the contents of the stills and edit caches
* Fix right eye EDL to show the correct track number
* Fix audio pop that can occur at cutpoints
* Fix varispeed disappearing when resizing V track on a pinned timeline
* Fix destination drive appearing correctly in the list on render/export panels
* Fix stripview jumping to a different position after clicking Join
* Fix audio levels changing when adjacent to black in the timeline
* Fix audio levels changing when black section is extended
* Fix AAF imports having incorrect audio levels
* Fix audio levelling to respect cut points
* Fix viewer focus when dragging and dropping a tile into a viewer
* Fix crash due to notes field hitting the character limit during consolidation
* Fix toolbox behaviour to not open when moving the mouse above or below toolbox area
* Fix toobox unpinned behaviour to close immediately when moving mouse away
* Change Solo button on mixer panel to unmute track if it is muted when clicking the Solo button
* Fix drag and dropping selected tracks from an edit to a bin
* Add memory check on startup
* Disabled AAF export in free Beta
* Fix LR and Mix 1-3 muting on the audio mixer panel
* Fix audio level line to move with the mouse wheel
* Fix varispeed to show as inactive when parked at the end of the edit
* Restore concurrent viewers setting to sync groups
* Fix sync-group 'when timecode, sync by' menu item
* Fix crash adding FX plugins
* Added ability to export audio track levels with AAF export (Full version only)
* Added ability to export audio clip gain with AAF export (Full version only)
* Added ability to export audio handles with AAF export (still under development)
* Added stereoscopic FX toolset (Full version only)
* Fix Bin archiving to support odd characters.
* Fix crash resizing viewers during playback
* Fix crash moving viewers during playback
* Fix crash and screen corruption after applying BITC
Fleißig die Burschen!
