VirtualBox - kostenloser virtueller PC
  • VirtualBox 4.0.0 (released 2010-12-22)
    This version is a major update. The following major new features were added:
    • Reorganization of VirtualBox into a base package and Extension Packs; see chapter 1.5, Installing VirtualBox and extension packs, see the manual for more information
    • New settings/disk file layout for VM portability; see chapter 10.1, Where VirtualBox stores its files, see the manual for more information
    • Major rework of the GUI (now called “VirtualBox Manager”):
      • Redesigned user interface with guest window preview (also for screenshots)
      • New “scale” display mode with scaled guest display; see chapter 1.8.5, Resizing the machine’s window, see the manual for more information
      • Support for creating and starting .vbox desktop shortcuts (bug #1889)
      • The VM list is now sortable
      • Machines can now be deleted easily without a trace including snapshots and saved states, and optionally including attached disk images (bug #5511; also, VBoxManage unregistervm --delete can do the same now)
      • Built-in creation of desktop file shortcuts to start VMs on double click (bug #2322)
    • VMM: support more than 1.5/2 GB guest RAM on 32-bit hosts
    • New virtual hardware:
      • Intel ICH9 chipset with three PCI buses, PCI Express and Message Signaled Interrupts (MSI); see chapter 3.4.1, “Motherboard” tab, see the manual for more information
      • Intel HD Audio, for better support of modern guest operating systems (e.g. 64-bit Windows; bug #2785)
    • Improvements to OVF support (see chapter 1.12, Importing and exporting virtual machines, see the manual for more information):
      • Open Virtualization Format Archive (OVA) support
      • Significant performance improvements during export and import
      • Creation of the manifest file on export is optional now
      • Imported disks can have formats other than VMDK
    • Resource control: added support for limiting a VM’s CPU time and IO bandwidth; see chapter 5.8, Limiting bandwidth for disk images, see the manual for more information
    • Storage: support asynchronous I/O for iSCSI, VMDK, VHD and Parallels images
    • Storage: support for resizing VDI and VHD images; see chapter 8.21, VBoxManage modifyhd, see the manual for more information.
    • Guest Additions: support for multiple virtual screens in Linux and Solaris guests using X.Org server 1.3 and later
    • Language bindings: uniform Java bindings for both local (COM/XPCOM) and remote (SOAP) invocation APIs
    In addition, the following items were fixed and/or added:
    • VMM: Enable large page support by default on 64-bit hosts (applies to nested paging only)
    • VMM: fixed guru meditation when running Minix (VT-x only; bug #6557)
    • VMM: fixed crash under certain circumstances (Linux hosts only, non VT-x/AMD-V mode only; bugs #4529 and #7819)
    • GUI: add configuration dialog for port forwarding in NAT mode (bug #1657)
    • GUI: show the guest window content on save and restore
    • GUI: certain GUI warnings don’t stop the VM output anymore
    • GUI: fixed black fullscreen minitoolbar on KDE4 hosts (Linux hosts only; bug #5449)
    • BIOS: implemented multi-sector reading to speed up booting of certain guests (e.g. Solaris)
    • Bridged networking: improved throughput by filtering out outgoing packets intended for the host before they reach the physical network (Linux hosts only; bug #7792)
    • 3D support: allow use of CR_SYSTEM_GL_PATH again (bug #6864)
    • 3D support: fixed various clipping/visibility issues (bugs #5659, #5794, #5848, #6018, #6187, #6570)
    • 3D support: guest application stack corruption when using glGetVertexAttrib[ifd]v (bug #7395)
    • 3D support: fixed OpenGL support for libMesa 7.9
    • 3D support: fixed Unity/Compiz crashes on natty
    • 2D Video acceleration: multimonitor support
    • VRDP: fixed rare crash in multimonitor configuration
    • VRDP: support for upstream audio
    • Display: fixed occasional guest resize crash
    • NAT: port forwarding rules can be applied at runtime
    • SATA: allow to attach CD/DVD-ROM drives including passthrough (bug #7058)
    • Floppy: support readonly image files, taking this as the criteria for making the medium readonly (bug #5651)
    • Audio: fixed memory corruption during playback under rare circumstances
    • Audio: the DirectSound backend now allows VMs to be audible when another DirectSound application is active, including another VM (bug #5578)
    • EFI: support for SATA disks and CDROMs
    • BIOS: reduce the stack usage of the VESA BIOS function #4F01 (Quake fix)
      OVF/OVA: fixed export of VMs with iSCSI disks
    • Storage: Apple DMG image support for the virtual CD/DVD (bug #6760)
    • Linux host USB support: introduced a less invasive way of accessing raw USB devices (bugs #1093, #5345, #7759)
    • Linux hosts: support recent Linux kernels with CONFIG_DEBUG_SET_MODULE_RONX set
    • Guest Additions: Shared Folders now can be marked as being auto-mounted on Windows, Linux and Solaris guests
    • Linux Additions: Shared Folders now support symbolic links (bug #818)
    • Linux Additions: combined 32-bit and 64-bit additions into one file
    • Windows Additions: automatic logon on Windows Vista/Windows 7 is now able to handle renamed user accounts; added various bugfixes
    VirtualBox 5.0 (released 2015-07-09)
    This is a major update. The following major new features were added:
    • Paravirtualization support for Windows and Linux guests to improve time-keeping accuracy and performance (see the manual for more information)
    • Make more instruction set extensions available to the guest when running with hardware-assisted virtualization and nested paging. Among others this includes: SSE 4.1, SSE4.2, AVX, AVX-2, AES-NI, POPCNT, RDRAND and RDSEED
    • xHCI Controller to support USB 3 devices (see the manual for more information)
    • Drag and drop support (bidirectional) for Windows, Linux and Solaris guests
    • Disk image encryption (see the manual for more information)
    • VMs can now be started in separate mode. The VM process is started headless while the frontend runs as a separate process which can be terminated without stopping the VM.
    • GUI: VM guest-content scaling support (including 3D acceleration)
    • GUI: New User Interface settings page for customizing status-bar, menu-bar and guest-content scaling
    • GUI: New Encryption settings tab for customizing encryption options for disk images
    • GUI: HiDPI support including application icons and optional unscaled HiDPI output on Mac OS X (including 3D acceleration)
    • GUI: Hotplugging support for SATA disks
    • New, modular audio architecture for providing a better abstraction of the host audio backends
    • Support for the NDIS6 networking framework on Windows (default on Vista and later)
    Changelog
    Downloads
