Hi es gibt eine neue Version der herrie's Firmware für den NEC 1300.
Version 105v11
Es wurde wieder einige Fehler behoben.
History:
v11 (1.05)
Changed writing strategy for many 2x media to get better results:) (There was a minor mistake in v10, which caused discs not to be written in the most optimized way :().
Added support for the following media:
DVD-R 4.7-01 (2x)
Solved problems with:
'Drive in use by another application'
'Blue screens on startup'
'Drive not being recognised by Windows'
'Drive detection errors in the BIOS'
All due to the version numbering I'll let the version number just be 1.05, so there won't be any problems!
SMMR01 (Should finally work now, I made a small mistake in v10 again)
Download unter:
http://herrie.rpc1.org/
