Da MediaInfo nicht aktualisiert wurde hab ich mich gestern Nacht entschieden noch mal alles neu auszuchecken und zu bauen.
Aber jetzt hängt es immer an: 'compile file 64bit'
--2015-01-15 08:08:05-- ftp://ftp.astron.com/pub/file/file-5.22.tar.gz
=> ‘file-5.22.tar.gz’
Resolving ftp.astron.com (ftp.astron.com)... 38.117.134.18
Connecting to ftp.astron.com (ftp.astron.com)|38.117.134.18|:21... connected.
Logging in as anonymous ... Logged in!
==> SYST ... done. ==> PWD ... done.
==> TYPE I ... done. ==> CWD (1) /pub/file ... done.
==> SIZE file-5.22.tar.gz ... 732556
==> PASV ... done. ==> RETR file-5.22.tar.gz ... done.
Length: 732556 (715K) (unauthoritative)
file-5.22.tar.gz 100%[===================================================>] 715.39K 647KB/s in 1.1s
2015-01-15 08:08:08 (647 KB/s) - ‘file-5.22.tar.gz’ saved [732556]
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking for builtin ELF support... yes
checking for ELF core file support... yes
checking for file formats in man section 5... no
checking build system type... x86_64-w64-mingw32
checking host system type... x86_64-w64-mingw32
checking for style of include used by make... GNU
checking for x86_64-w64-mingw32-gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking for gcc option to accept ISO C99... -std=gnu99
checking for gcc -std=gnu99 option to accept ISO Standard C... (cached) -std=gnu99
checking how to run the C preprocessor... gcc -std=gnu99 -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether byte ordering is bigendian... no
checking whether ln -s works... no, using cp -pR
checking how to print strings... printf
checking for a sed that does not truncate output... /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc -std=gnu99... H:/media-autobuild_suite/msys64/mingw64/x86_64-w64-mingw32/bin/ld.exe
checking if the linker (H:/media-autobuild_suite/msys64/mingw64/x86_64-w64-mingw32/bin/ld.exe) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /mingw64/bin/nm -B
checking the name lister (/mingw64/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 8192
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-w64-mingw32 file names to x86_64-w64-mingw32 format... func_convert_file_msys_to_w32
checking how to convert x86_64-w64-mingw32 file names to toolchain format... func_convert_file_msys_to_w32
checking for H:/media-autobuild_suite/msys64/mingw64/x86_64-w64-mingw32/bin/ld.exe option to reload object files... -r
checking for x86_64-w64-mingw32-objdump... no
checking for objdump... objdump
checking how to recognize dependent libraries... file_magic ^x86 archive import|^x86 DLL
checking for x86_64-w64-mingw32-dlltool... no
checking for dlltool... dlltool
checking how to associate runtime and link libraries... func_cygming_dll_for_implib
checking for x86_64-w64-mingw32-ar... no
checking for ar... ar
checking for archiver @FILE support... @
checking for x86_64-w64-mingw32-strip... no
checking for strip... strip
checking for x86_64-w64-mingw32-ranlib... no
checking for ranlib... ranlib
checking command to parse /mingw64/bin/nm -B output from gcc -std=gnu99 object... ok
checking for sysroot... no
checking for x86_64-w64-mingw32-mt... no
checking for mt... no
checking if : is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc -std=gnu99 supports -fno-rtti -fno-exceptions... no
checking for gcc -std=gnu99 option to produce PIC... -DDLL_EXPORT -DPIC
checking if gcc -std=gnu99 PIC flag -DDLL_EXPORT -DPIC works... yes
checking if gcc -std=gnu99 static flag -static works... yes
checking if gcc -std=gnu99 supports -c -o file.o... yes
checking if gcc -std=gnu99 supports -c -o file.o... (cached) yes
checking whether the gcc -std=gnu99 linker (H:/media-autobuild_suite/msys64/mingw64/x86_64-w64-mingw32/bin/ld.exe) supports shared libraries... yes
checking dynamic linker characteristics... Win32 ld.exe
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking whether the -Werror option is usable... yes
checking for simple visibility declarations... yes
checking for ANSI C header files... (cached) yes
checking whether sys/types.h defines makedev... no
checking sys/mkdev.h usability... no
checking sys/mkdev.h presence... no
checking for sys/mkdev.h... no
checking sys/sysmacros.h usability... no
checking sys/sysmacros.h presence... no
checking for sys/sysmacros.h... no
checking for sys/wait.h that is POSIX.1 compatible... no
checking for stdint.h... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for inttypes.h... (cached) yes
checking for unistd.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking utime.h usability... yes
checking utime.h presence... yes
checking for utime.h... yes
checking wchar.h usability... yes
checking wchar.h presence... yes
checking for wchar.h... yes
checking wctype.h usability... yes
checking wctype.h presence... yes
checking for wctype.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking err.h usability... no
checking err.h presence... no
checking for err.h... no
checking xlocale.h usability... no
checking xlocale.h presence... no
checking for xlocale.h... no
checking sys/mman.h usability... no
checking sys/mman.h presence... no
checking for sys/mman.h... no
checking for sys/stat.h... (cached) yes
checking for sys/types.h... (cached) yes
checking sys/utime.h usability... yes
checking sys/utime.h presence... yes
checking for sys/utime.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for an ANSI C-conforming const... yes
checking for off_t... yes
checking for size_t... yes
checking for struct stat.st_rdev... yes
checking for struct tm.tm_gmtoff... no
checking whether struct tm is in sys/time.h or time.h... time.h
checking for struct tm.tm_zone... no
checking whether tzname is declared... yes
checking for tzname... yes
checking for tm_zone in struct tm... no
checking whether tzname is declared... (cached) yes
checking for tzname... (cached) yes
checking for tm_isdst in struct tm... yes
checking whether daylight is declared... yes
checking for daylight... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for _LARGEFILE_SOURCE value needed for large files... no
checking for mbstate_t... yes
checking for struct option in getopt... yes
checking for pid_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for int32_t... yes
checking for uint64_t... yes
checking for int64_t... yes
checking for intptr_t... yes
checking for uintptr_t... yes
checking for stdlib.h... (cached) yes
checking for sys/param.h... yes
checking for getpagesize... yes
checking for working mmap... no
checking vfork.h usability... no
checking vfork.h presence... no
checking for vfork.h... no
checking for fork... no
checking for vfork... no
checking whether mbrtowc and mbstate_t are properly declared... yes
checking for gcc compiler warnings... yes
checking for strerror... yes
checking for strndup... no
checking for strtoul... yes
checking for mkstemp... yes
checking for mkostemp... no
checking for utimes... no
checking for utime... yes
checking for wcwidth... no
checking for strtof... yes
checking for newlocale... no
checking for uselocale... no
checking for freelocale... no
checking for setlocale... yes
checking for getopt_long... yes
checking for asprintf... yes
checking for vasprintf... yes
checking for strlcpy... no
checking for strlcat... no
checking for getline... no
checking for ctime_r... no
checking for asctime_r... no
checking for pread... no
checking for strcasestr... no
checking for fmtcheck... no
checking for gzopen in -lz... yes
checking for regexec in -lgnurx... no
configure: error: libgnurx is required to build file(1) with MinGW
make: *** No targets specified and no makefile found. Stop.
make: Nothing to be done for 'install'.
build file-5.22 failed...
delete the source folder under '/build64' and start again,
or if you know there is no dependences hit enter for continue it
first close the batch window, then the shell window
Alles anzeigen
Hab auch schon mehrfach den 'file-5.22'-Ordner im build64 Ordner gelöscht, hängt aber immer an der gleichen Stelle.
