Hallo zusammen,
vielleicht hat jemand eine Lösung bei folgendem Problem?
Ich nutze StaxRip 2.0.2.0 (2.0.4.0 habe ich auch versucht, aber das gleiche Problem) und manchmal habe BluRay Audiospuren E-AC3 und sobald ich so eine konvertieren möchte kommt folgender Fehler:
Error Demux M2TS using eac3to 3.34 (2.0.2.0)
Demux M2TS using eac3to 3.34 failed with exit code: 1 (0x1)
The exit code might be a system error code: STATUS_WAIT_1
The exit code might be a system error code: Unzulässige Funktion.
--------------------- Demux M2TS using eac3to 3.34 ---------------------
"C:\Program Files\StaxRip v2.0.2.0\Apps\Audio\eac3to\eac3to.exe" "E:\Filme\Aladdin E-AC3\ALADDIN\BDMV\PLAYLIST\" 1) 2: "E:\Filme\Aladdin E-AC3\ALADDIN\ALADDIN\ALADDIN.mkv" 5: "E:\Filme\Aladdin E-AC3\ALADDIN\ALADDIN\ALADDIN ID5 German.eac3" 1: "E:\Filme\Aladdin E-AC3\ALADDIN\ALADDIN\ALADDIN_chapters.txt" -progressnumbers
M2TS, 1 video track, 6 audio tracks, 9 subtitle tracks, 2:07:59, 24p /1.001
1: Chapters, 16 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz, dialnorm: -4dB
(core: DTS, 5.1 channels, 1509kbps, 48kHz, dialnorm: -4dB)
4: AC3, Czech, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
5: E-AC3, German, 7.1 channels, 896kbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, 512kbps, 48kHz, dialnorm: -27dB)
6: AC3, Modern Greek, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
7: E-AC3, Italian, 7.1 channels, 896kbps, 48kHz, dialnorm: -27dB
8: AC3, Polish, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB
9: Subtitle (PGS), English
10: Subtitle (PGS), Czech
11: Subtitle (PGS), German
12: Subtitle (PGS), Modern Greek
13: Subtitle (PGS), Italian
14: Subtitle (PGS), Polish
15: Subtitle (PGS), Czech
16: Subtitle (PGS), Modern Greek
17: Subtitle (PGS), Polish
Creating file "E:\Filme\Aladdin E-AC3\ALADDIN\ALADDIN\ALADDIN_chapters.txt"...
a05 Extracting audio track number 5...
v02 Extracting video track number 2...
a05 Removing AC3 dialog normalization...
Applying (E-)AC3 delay failed.a05
v02 Muxing video to Matroska...
Aborted at file position 1048576.
StaxRip.ErrorAbortException: Demux M2TS using eac3to 3.34 failed with exit code: 1 (0x1)
bei StaxRip.Proc.Start() in C:\Users\frank\Daten\Projekte\VB\staxrip\General\Proc.vb:Zeile 338.
bei StaxRip.MainForm.OpenEac3toDemuxForm(String playlistFolder, Int32 playlistID) in C:\Users\frank\Daten\Projekte\VB\staxrip\Forms\MainForm.vb:Zeile 4972.
Display More
