ZitatAlles anzeigenChange log:
Bug fixes:
'Fixed issue when the cells weren't always put in the correct order
'Progressive / interlaced flags now correct
'Fixed a problem with frame stills (commonly chapter stills)
----> at the moment I haven't found a way to accurately reauthor a
stilll frame with the sub picture in the correct place (don't know
whether this is a vsrip issue or ifoedit yet). So as a workaround
any vobid that has 0.12 cells (PAL)or 0.15 cells (NTSC) is left
alone and reintegrated into the VOB. (but commonly this type of vob
id has 50+ cells and total size less that 10MB, so not much of a
problem)
'Fixed issue when a cell is listed in VTSM_C_ADT and is in the VOB
stream, but is never called, ie it isn't listed in VTSM_PGCI_UT -
this was causing synch errors - and although rare was an annoyance
'Fixed issue when occasionally sub2sup_cli would loop endlessly
without processing
'Fixed issue where not every NAV pack in the VOB was updated
'Infinifilm should now workEnhancements:
'When running IfoUpdate facility to autodetect Restricted Cells
caused by Scenarist. The cells will be chnaged IF the original does
not have a Restricted cell
'Facility to auto create a DVD image on completion of IfoUpdate
'If foldername has non-standard letters (eg å,ä,ö) they will
automatically be replaced
----> this allows greater compatability with applications used -
thanks to Ripe73
'Support for Avisynth 2.08 now added
'Sub2sup lang_de.dll now removed from install - thanks to rasta21
for this
'Facility to use the new dvd2avi and mpeg2dec3 added (remember these
are still BETA)
'Have now added support for all languages available - full DVD spec
'ConvertToYUY2() has been replaced by ConvertToYUY2(interlaced=true)
for 2.5+
'Auto detection if avisynth version changed
'Multiple audio streams in menus now supportedGUI:
'Removed menu bar - not necessary now with all the buttons - just
left contact
'Choice of dvd2avi cannot be saved to the registry - user makes the
choice every time
----> I will automatically use the new dvd2avi when a good stable
version is available
'The save button in button bar is now used for save all settings
instead of output location
'All buttons are now disabled when NuMenu4u is runningKnown Issues:
There is still no reliable way to stop the message boxes popping up during IfoUpdate. This is a bug with IfoUpdate when run from commandline
numenu4u release candidate 1
Zitat Zeul:
NuMenu4u RC1 Build 2
New Build available.
Changelog as follows:
Enhancements:
• Log file now saved to working directory
• Check for corrupt ifo's that would lead to various update
errors
• If a cell is reused across different PGC and the PGC have
different colour palettes then a default palette is used in
scenarist and the appropriate palette transferred back into
the PGC on updating
• Option to set the default output to either drive root or My
Documents
• Ability to re-encode stills - useful for when doing a major
alteration [this is not intended to be used to reduce the
file size so the bitrate has been preset]
• CCE is now run in batches of 75 which increases encode time
• Special builds [designed for NuMenu4u & future builds of
Doitfast4u] of vsrip & vsconv now included. Special thanks
to D3s7 for his work on these files.
• Because of these new builds the sub and button highlights
are very accurate
• DvdDecrypter is now only run once , and if absolutely
necessary a second time for cellid demux
• If more than 50% of a video stream has dummy cells then
these cells are removed
• Major size reduction of script - Every command is analysed
and only the title details
necessary for correct linking are now included in the
scenario. Faster import results
• Option to use SoftEncode as the default Wav to AC3 converter
• Because of a SoftEncode bug on some Operating Systems
ability to test for stability is included in the Audio
Options. If SoftEncode is unstable then the fix is to delete
the registry entries and will be enabled automatically
• Option to fix crc audio errors
• Browseforfolder now used for save folder. If the chosen
folder is not empty then the folder will be deleted
• A new debug ability is now available. If NuMenu4u fails or
the result is not correct, selecting the debug screen will
enable you to send me the files needed to fix. NuMenu4u will
select the files required, zip them up and e-mail them to
me. The e-mail will not use your default client.
• GUI now includes progress barsBug Fixes:
• Wav files were not being demuxed
• Rewrite of sst routines
• Error fixed when there were no subs in a VTS
• Correction of button command for when VTS=0
• Correction to SUB/AUDIO command when set by GPRM
• Alteration to GOP details in the ECL file
• Checking for Scenarist is now run only once not every time
NuMenu4u is opened
• Major fix to the settings being saved correctly
• Correction to StillOff UOP - this was always set to offChanges:
• Avisynth settings now independant of main settings
• Quantizer settings in CCE are now in Quality settings; as
this can be important and does not affect encoding time
• After compile the temp files are no longer moved. These
files do not affect the bitrate calcs in doitfast4u. This
option has been removed
• Delaycut is now used instead of delaycorrectorFor accuracy the latest build of DvdDecrypter should be used
The installer has been zipped up with some other files. Run the bat file to begin installation.
http://www.numenu4u.com/NuMenu4u.zip
Enjoy (I hope!)
Zitat von Zeul
I am pleased to announce the release of NuMenu4u RC2
Changelog:
Bug Fixes:
Fix to the Temp_Settings error
Change to the para.lst for when Vsrip is run more than once.
Removes the Vsconv error
scanfolderforfilecopy routine replaced
Due to a scripting error on my part the threshold from DIF4U was never passed into the app.
Correction to the SoftEncode registry fix - Please rerun.
Fix whereby scenarist 2.6 would never be called
Fix to minimze to system tray - would restore itself after authoring / pause for script verificationChanges:
Alteration to the contrast conversion from VOB file to the scirpt (It was impossible to have a contrast of 0& for selection / action highlights)
To coincide with the new generation of menus, the normal display is now taken from the SST file (sometimes now <> 0%)
Complete change to the conversion rule for subs
Change to the bit allocation to determine if VOB is letterboxed from the IFO
Alteration to the way the check boxes in the treeview responded
Lots of code cleanup and optimizing
New e-mail debug, I didn't like the previous one; Now have a normal install once againAdditions:
Added ability to save the setting to use original assets (requires the save box also being checked)
Added the option to force a re-run of scenarist scan, for when new versions are installed - under Scenarist Tab
Added an additional check for incorrect cell commands in the IO caused by original author error - Removes the cell command error in Scenarist on compileEdit: NuMenu4u RC2 Build 3 released
This corrects the Overflow error and installs/registers the MSWINSCK.OCX. I was under the impression that this file was pre-installed in the OS. My mistake.
Zeul hat NuMenu4u RC2 Build 4 released
Bug Fixes:
Alteration to the sub starttime - occasional button not compiled
Variety of bug fixes to correct copying files when dif4u threshold is higher
When called from dif4u the first drive that had a valid dvd structure would be used , not the intended drive
Settings now saved again
Some changes to stop overflow error
Major change to the AVS script editor. many of the parameters were never passed into the NTSC scripts,
Deinterlacing now provides the correct scripts
Major fix to the passing of the encoded m2v files into the NEW_M2V folder for scenarist.
Major fix to a dumb error that wouldn't allow any menu PGCs to be created in non-processed VTSs - this would cause a variety of scenarist compile errors if VIDEO_TS.VOB was being processed
Fix to scanning for dummy cells - where cell demux needs to be invoked firstEnhancements:
A new special script for PAL deinterlacing should now be used - I have not included any particular script for this - use your own
Added ability to specify whether the menus are progressive or interlaced by default (in the Quality settings) NB see the note!
New installer that will remove previous version and ALL settings if wanted - Recommended -
Zeul hat NuMenu4u RC2 Build 5 released
Changelog:
CCE is now processed in batches of 50 not 75 - CCE would on occasion complain of unsupported frame size or avifileinfo error
NTSC_FILM is now derived from the log file instead of internal computations
Change to the internal routines for support of multiple bmps per cell
fix: if there was > 1 bmp per cell the first bmp did not always have the correct end time / duration
fix: if the palette needed to be replaced in the ifo becuase of multiple cell use, then only the video_ts.ifo would have been fixed
HMMMM, Actually remembered to include the zipping dll this time! May account for the strange results
Found the problem which was resulting in no VOB file in the SUB folder or the audio not being processed.D3s7 hat eine neue version von automate_scenarist rausgebracht.
Wenn wer probleme hat einfach die alte ersetzten. -
NuMenu4u RC2 Build 6 erschienen:
corrects the shutdown procedure,
adds support for multiple audio streams in reused vobs - should correct the NEMO audio errornew executable only (unzip & copy into install folder):
http://www.numenu4u.com/NuMenu4u.RC2.BUILD.6.zipNuMenu4u Scenarist Version FULL INSTALL:
http://www.numenu4u.com/NuMenu4u.exe -
NuMenu4u RC2 Build 7 released
Sets the CCE max bitrate correctly depending on audio streams.
Zeul hat Numenu4u RC3 Build 1 released
Enhancements:
Added ability to add silence to audio streams, so that they equal video length; required for seamless cells (Audio Tab)
Complete new Automate_Scenarist from myself and D3s7, which includes a visible LOG file.
To enable the showing of the LOG in Automate see the new option in Scenarist TabBug Fixes:
On one occasion there was an overflow in the IFO creation - corrected
Some PGCs were mistakenly labelled as Dummy, so no cells created in Scenarist Layout - corrected
Finally found the bug that was causing pulldown to not be run (very occasionally). Reason - spaces in the folder names, code altered to reflect this. -
Zeul hat Numenu4u RC4 Build 1 released
ZitatAn update build is now available. Instead of releasing a final I have decided to include a couple of new features first
Enhancements:
Format Conversion (under avisynth tab) - NTSC -> PAL and vice versa
Recovery Console - this new build creates a 2nd log file that is designed specifically to redo the same menu again, from a designated starting position. This could be to reencode for example. You can also start from any VTS. NB make sure that the ISO is still mounted on the same drive.
Under Encode tab, the option now exists to set the number of assets to be included in each ECL file (Default = 50). This is for where CCE drops certain encodes.
In Default options there is now an option to set the duration of multiple subs per cell. This is because of a scenairst restriction. This was primarily designed to stop Spiderman R1 failing due to 200+ subs per cell! Use this only if necessary.
Slight alteration to AutomateBug Fixes:
Alteration to the code to allow Pulldown to run with spaces in the folder names.
Change to the IFO scan routine to allow vobids out of sequence.
Other internal fixes.Known Issues:
The format conversion is still in its infancy , but in my tests everything works as it should. Your main decision is whether to drop frames so that the video length is the same, or use every frame and alter the audio length. Because Besweet produces non-compilant AC3 my recommendation is : IF you have softencode then keep every frame, else drop some (this will then use the original audio). The subs and buttons are automatically resized BUT if the sub is a layer of writing that should superimpose over the video/still exactly sometimes this is displaced by a couple of pixels. Using the avs script AssumeFPS(xx) will keep every frame. Kerneldeint has been added to the install package for the creation/deletion of frames.
The script is under avisynth tab.Because of the changes a complete install is required.
Zeul hat Numenu4u RC4 Build 1.1 released
fix: left the script generation in design mode - only 1 track would be created.
Zeul hat Numenu4u RC4 Build 1.2 released
bug fixes:
Now correctly changes the avs script for field order in format conversion.
CBR now uses the AVG bitrate given not a default of 9000
CBR for stills is now set to max of 8000
Change to GOP settings for conversion - it was restricting N=3, N/M=4 even in NTSC->PAL
Alteration to a pgc/button command. Was not getting the correct GPRM value - was resulting in a Scenarist error.
Internal fixes to the UOPs script creation and cc file creation when using recovery console.Enhancements:
Now processes the PGC command for GOUP where the command is ffff -> Resume PGC. This was causing an overflow error also.
Option in Default tab to force a min duration for bmps. Only use if absolutely necessary!!Vielleicht könnte wer den Titel verallgemeinern
